12748 Discussions
HELP,I can't generate Hardware interrupt
I need help,please
What I want is : When I press a button ON Board, Nios Let LEDs lights.Of course,the LEDs is turned off before.(The board is DIY,Just a cyclone ep1c3t144c8 without flash and sdram.I download program to On_chip 4K ram for test. this is a test board,later I will make Nios with flash and sdram on PCB.SO,thanks for advice!!)
the Problem is,Software is make just like nios example: nios\examples\software\count_binary
software:
static void handle_button_interrupts(void* context, alt_u32 id)
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(0x1820, 0);
//0x1820 is the addbase, input of my button for interrupts
//problem is not getin here,I put breakpoint here,but never stop!
IOWR_ALTERA_AVALON_PIO_DATA(0x1830,0xf);//Let leds light!
// 0x1830 is the addbase of leds
int alt_main (void)
alt_u8 led = 0x00;
alt_u16 i=0x0;
alt_u16 j=0x0;
alt_u8 inbit;
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(0x1820, 0xf);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(0x1820, 0x0);
j=alt_irq_register( 0, 0, handle_button_interrupts );
//The first para is 0:the IRQ on SOPC,I set it as 0
//the 2nd para is 0: the number to interrupt ,I set it 0
//the 3rd para is handle_button_interrupts:my interrupt gate!
//I set breakpoint here,after this instruction ,j gets 0.it indicate that registe success!
the NIos developer's handbook says: Button is pressed, generating an IRQ.
But when I press the button,Irq didn't generate!!
The step I make SOPC:
In SOPC,When I set key_in_pio,(IP is PIO),
1.In the first Dialog window,Width set "1"bits.and choose"Input ports only."
2.In the 2nd Dialog window,I just let it Generate IRQ, I choose "Level".then Pressed finish.
Then in the main window,I set pio's IRQ as"0";
other IP:cpu,led pio,key_in_pio,onchip memory_0;
Out of the FPGA,I let a Key to triger .When I press button,the level is 3.3v;otherwise the level is 0v;
Thanks for spending time on reading this.
- better to use edge triggered interrupts in your input pio
- i don't know if you need a system timer, this normally
has IRQ0 assigned.
does your program runs normal in debugger
e.g let a led blink in while loop ?
while(1) {
usleep(100000);
led ^= 0x01;
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,led);
Fischer, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
thanks,I will try to use IRQ1,and use edg.
the LED is OK in normal test(It can lights and blank),and I will let it blank in the interrupt test program when the irq not generate!.
Fischer,
I am afraid ,I also can&#39;t get IRQ.
I found that "status" is always &#39;0&#39;.it means IE is not enable.
I thought the register can enable IE,I don&#39;t know I miss what .
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
I also found that there is a weird problem:
the instruction :
//r2=10
WRCTL ienable,r2
but after this instructon ,I traced the debug in disassumbly,the ienable didn&#39;t change.
can anyone help!
Hello TommyCP,
i tried the following in an ep1c3t144 chip, quartus 5.1 nios 5.1,
and it works as expected.
in to schematic i have:
input clk : 50Mhz
input reset_n , connected to VCC in fpga
inport button [7..0] (PIO_0)
outport led [7..0] )PIO_1)
cpu nios II/e
jtag debug module: 0x00..0x7ff
onchip memory 4k
add: 0x1000..0x1fff
pio_0 8 bit input only,sync capture faling edge, generate irq edge
add: 0x800 irq:0
pio_1 8 bit output only
add: 0x810
uses hello world small as start and modified it as following
switch on input 0 generates irq and toggles output 1
output 0 is toggled in while loop
program compiles:
make -s all
Compiling hello_world_small.c...
../hello_world_small.c: In function `main&#39;:
../hello_world_small.c:88: warning: passing arg 2 of `alt_irq_register&#39; discards qualifiers from pointer target type
Linking hello_world_small_1.elf...
Info: (hello_world_small_1.elf) 2080 Bytes program size (code + initialized data).
Info: 2016 Bytes free for stack + heap.
Post-processing to create onchip_memory_0.dat
Post-processing to create onchip_memory_0.hex
Post-processing to create onchip_memory_0.sym
Build completed
# include <stdio.h># include <unistd.h> // usleep()# include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_pio_regs.h"
static void handle_button_interrupts(void* context, alt_u32 id);
volatile alt_u8 led=0;
/* A variable to hold the value of the button pio edge capture register. */
volatile int edge_capture;
volatile int irq_count;
# define BUTTON_PIO_BASE PIO_0_BASE# define BUTTON_PIO_IRQ PIO_0_IRQ# define LED_PIO_BASE PIO_1_BASE
int main()
// Enable all 4 button interrupts.
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE, 0xf);
// Reset the edge capture register.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0x0);
// Register the interrupt handler.
alt_irq_register( BUTTON_PIO_IRQ,&edge_capture, handle_button_interrupts );
while(1) {
usleep(100000);
led ^= 0x01;
return 0;
// Cast context to edge_capture&#39;s type. It is important that this be
// declared volatile to avoid unwanted compiler optimization.
volatile int* edge_capture_ptr = (volatile int*) context;
// Store the value in the Button&#39;s edge capture register in *context.
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE);
// Reset the Button&#39;s edge capture register.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0);
led^=0x02;
// irq_count++;
Fischer,
I really thank you a lot.
I will do exactly as you did.
Fischer,
I actually works as expects,thanks a lot.
now the instruction
"WRCTL ienable,r2"
works,It can enable IRQ.
the difference between us:
you uses "hello world small" as start,while I use"hello led".
other different like :memory addr,input triger(you use &#39;fall edge&#39;;I &#39;rise edge&#39; ),and some I think less important set.
all in all.thank you a lot!
Best wishs.
I have met the same problem before.
So far, I don&#39;t know the root reason cause this issue.
I just try to modify the IRQ, and sometimes it works, sometimes not...
