HELP!!
This is my program:
# include <stdio.h># include <sys/types.h># include <fcntl.h>
int main()
int p_button=NULL;
unsigned int x=0;
p_button=open("/dev/ttyS0",O_RDWR);
if(p_button<0)
printf("\nopen uart device ERROE!\n");
return 0;
for(x=200;x<256;x++)
write(p_button,&x,1);
printf("write rs232 end!\n");
read(p_button,&x,1);
printf("read rs232 end!\n");
if(x==0) {close(p_button);return 0;}
close(p_button);
These are the problems:
Severity Description Resource In Folder Location Creation Time
1 initialization makes integer from pointer without a cast test.c hello line 7 May 23, 2006 9:56:29 AM
1 implicit declaration of function `write&#39; test.c hello line 17 May 23, 2006 9:56:29 AM
1 implicit declaration of function `read&#39; test.c hello line 19 May 23, 2006 9:56:29 AM
1 implicit declaration of function `close&#39; test.c hello line 21 May 23, 2006 9:56:29 AM
They are warning !
But,it always die in "read",Why??
another problem :when I download program(*.exe) in the target though FTP, the problem can&#39;t run. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
Thanks!!
hi,
I think the problem is with a missing include library;
because when it says : "implicite declaration of function read()"
it means that the compiler can&#39;t find definition of the function.
so u must :
1) be shure that all required libraries are included
2) specify the whole path for types.h in :# include <sys/types.h>
best regards http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
--- Quote Start ---
originally posted by sdhnain@May 23 2006, 11:05 PM
hi,
i think the problem is with a missing include library;
so u must :
best regards  http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15532)
--- quote end ---
--- Quote End ---
First,thanks!
there are very much lib about serial port,so I don&#39;t know use which lib ?
what can i do?
You can do a man on whatever function you have in question:
man read
Try it on LINUX or try it on google.
Results:
# include <unistd.h>
ssize_t read(int fd, void *buf, size_t count);
And a whole pile more of information about the read function.
