12745 Discussions
[Hardware Testing]How to connect the jtag-MM in Top level. ref. [Low Latency Ethernet 10G MAC Intel Cyclone 10 GX FPGA IP Design Example User Guide]
ASey
I need some help. I want to know what is error and how to do it.
​Where should I check?
If anyone has ever run a demo board, please help me.
Thanks in advance
<Used cyclone 10gx DEV>
[Top file in sample project]
module altera_eth_top # (
    parameter NUM_CHANNELS = 2,
    parameter DEVICE_FAMILY = "Cyclone 10 GX"
  input  wire      csr_clk,
  output wire      core_clk_312,
  input  wire      ref_clk_clk,
  input  wire      master_reset_n,
  output wire      sfp0_txdisable,
  output wire      sfp1_txdisable,
  output wire      xfp_txdisable,
  output wire [1:0]   SFPP0_RATE_SEL,
  output wire [1:0]   SFPP1_RATE_SEL,
  // LED
  output wire [NUM_CHANNELS-1:0]     block_lock_n,
  output wire [NUM_CHANNELS-1:0]     tx_ready_export_n,
  output wire [NUM_CHANNELS-1:0]     rx_ready_export_n,
  // debug clock
  output wire      core_clk_156,
  output wire [NUM_CHANNELS-1:0]     tx_serial_data,
  input  wire [NUM_CHANNELS-1:0]     rx_serial_data,
  output wire       core_pll_locked_n,
  output wire       atx_pll_locked_n,
  output wire [NUM_CHANNELS-1:0]    avalon_st_rxstatus_valid_156,
  output wire [NUM_CHANNELS-1:0][39:0] avalon_st_rxstatus_data_156,
  output wire [NUM_CHANNELS-1:0][6:0] avalon_st_rxstatus_error_156
wire              csr_rst_n;
wire              tx_rst_n;
wire              rx_rst_n;
wire [NUM_CHANNELS-1:0]     block_lock;
wire [NUM_CHANNELS-1:0]     tx_ready_export;
wire [NUM_CHANNELS-1:0]     rx_ready_export;
wire              core_pll_locked;
wire              atx_pll_locked;
assign csr_rst_n = master_reset_n;
assign tx_rst_n = master_reset_n;
assign rx_rst_n = master_reset_n;
assign sfp0_txdisable = 1'b0;
assign sfp1_txdisable = 1'b0;
assign xfp_txdisable= 1'b0;
assign SFPP0_RATE_SEL = 2'b11;
assign SFPP1_RATE_SEL = 2'b11;
assign block_lock_n = ~block_lock;
assign tx_ready_export_n = ~tx_ready_export;
assign rx_ready_export_n = ~rx_ready_export;
assign core_pll_locked_n = ~core_pll_locked;
assign atx_pll_locked_n = ~atx_pll_locked;
altera_eth_10g_mac_base_r #(
    .NUM_CHANNELS(NUM_CHANNELS),
    .DEVICE_FAMILY(DEVICE_FAMILY)
  ) dut_inst (
  .csr_clk      (csr_clk),
  .csr_rst_n     (csr_rst_n),
  .core_clk_312    (core_clk_312),
  .tx_rst_n      (tx_rst_n),
  .rx_rst_n      (rx_rst_n),
  .ref_clk_clk    (ref_clk_clk),
  .core_clk_156    (core_clk_156),
  // csr interface
  .csr_read      (1'b0),
  .csr_write     (1'b0),
  .csr_writedata   (32'b0),
  .csr_readdata    (),
  .csr_address    (16'b0),
  .csr_waitrequest  (),
  .tx_ready_export  (tx_ready_export),
  .rx_ready_export  (rx_ready_export),
  .block_lock     (block_lock),
  .tx_serial_data   (tx_serial_data),
  .rx_serial_data   (rx_serial_data),
  .core_pll_locked  (core_pll_locked),
  .atx_pll_locked   (atx_pll_locked),
  .avalon_st_rxstatus_valid_156      (avalon_st_rxstatus_valid_156),
  .avalon_st_rxstatus_data_156      (avalon_st_rxstatus_data_156),
  .avalon_st_rxstatus_error_156      (avalon_st_rxstatus_error_156)
endmodule
[ To Interface the Jtag]
Add to Top file...........
wire           [31:0]   jtag_if_address;
wire              jtag_if_read;
wire             jtag_if_write;
wire           [31:0]   jtag_if_writedata;
wire           [31:0]   jtag_if_readdata;
wire                jtag_if_readdatavalid;
wire                jtag_if_waitrequest;
  // JTAG Master
  alt_jtag_csr_master jtag_master (
    .clk_clk              (csr_clk),
    .clk_reset_reset          (~reset_n),
    .master_address         (jtag_if_address),
    .master_write           (jtag_if_write),
    .master_read            (jtag_if_read),
    .master_writedata         (jtag_if_writedata),
    .master_readdata          (jtag_if_readdata),
    .master_readdatavalid       (jtag_if_readdatavalid),
    .master_waitrequest        (jtag_if_waitrequest)
After compiling, Run tcl in Tcl console
% pwd
C:/intelFPGA_pro/SNS_Q102
% cd c:/intelFPGA_pro/SNS_Q102/hwtesting/system_console/
% pwd
C:/intelFPGA_pro/SNS_Q102/hwtesting/system_console
% source loopback_conf.tcl
​/devices/10CX220Y@2#USB-1/(link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_0/jtag_phy_0.jtag/master
Info: Opened JTAG Master Service
Read loopback status
error: master_read_32: This transaction did not complete in 60 seconds. System Console is giving up.
  while executing
"master_read_32 $jtag_master $address_hex 1"
  (procedure "rd32" line 6)
  invoked from within
"rd32 [expr {$CHANNEL*0x10000 + 0xC000}] 0x800 0x00"
  (file "loopback_conf.tcl" line 25)
  invoked from within
"source loopback_conf.tcl"
Please. I need your help.
Deshi_Intel
Hi Asey,
I presume you are referring to Cyclone 10 GX 10G Ethernet example design from below link
If you are using Cyclone 10 dev kit board
  • Then make sure you configure the on board clock generator frequency correctly as per attached pic
  • JTAG master rely on on-board JTAG connection. You want to check to ensure your JTAG connection is working as well. You can use "jtagconfig" command to verify on board JTAG connection or run "jtagconfig --setparam 1 JtagClock 6M" command to reduce JTAG frequency to improve the signal quality
  • You are running Avalon-ST loopback via "source loopback_conf.tcl". This is the loopback where external Ethernet tester generate traffic to FPGA Eth RX pin, loopback internally inside FPGA and then re-transmit back to FPGA Eth tx pin then to Ethernet tester. So, you need to verify your tester setting as well
else if you are using your own board
  • Then make sure you configure all the FPGA pin assignment correctly and double check your board FPGA power, JTAG, clock and reset connection before you run the Ethernet testing
dlim
