Dear friends,
Recently I have a try for loading uclinux on FPGA. And I do it as Altera wiki-Install Nios II Linux. http://www.alterawiki.com/wiki/install_nios_ii_linux And when I have install the gcc-4.2 and then make commands as list: --tar xf <path_to>nios2-linux-20100621.tar --cd nios2-linux --cd uClinux-dist --make menuconfig I was stack in this step,the message is "make: *** No rule to make target `menuconfig'. Stop." Any one occured this problem before?Please give some advice. Thank you a lot! Davidchaning链接已复制
6 回复数
Did you load .ptf file? You need to do something like
make vendor_hwselect SYSPTF=<path>/my_sopc.ptf Try this even if the wiki says that this step must be done after. Often I had to type "make menuconfig" before and after "make vendor_hwselect"are you sure that the hw_select shall be done?
If you follow latest branches (see http://www.alteraforum.com/forum/showthread.php?t=31829), the device tree fashion should be followed. hw_select is the way that was used in the old nioswiki times.hw_select doesn't work any more
you need to create header file with sopc2swheaders script and use it The wiki is not updated, some times it is a mix of old and new. your problem could be missing packages.
