12748 Discussions
Help me!Configure uCLinux kernel eeror in NiossII!
i want to embed uCLinux into NiosII soft cpu, and i have install the Microtronix uCLinux 1.4, but when i create a project in NiosII-ide, i can not configure kernel of uCLinux correctly(winXP), it has some errors that shows in following PIC, please help me!Thanks
NiosII6.1+Qii6.1 +Micro uCLinux1.4
http://www.dzkf.net/attachment.php?aid=7635&noupdate=yes&nothumb=yes
http://www.dzkf.net/attachment.php?aid=7634&noupdate=yes&nothumb=yes
eclipse.buildId=M20060629-1905
java.version=1.5.0_06
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -data D:\altera_proj\nios2linux\nios2_C35\workspace -os win32 -ws win32 -arch x86
Error
Mon Mar 26 14:26:32 CST 2007
An exception occurred while dispatching debug events.
java.lang.NullPointerException
at org.eclipse.cdt.launch.AbstractCLaunchDelegate.getProjectName(AbstractCLaunchDel
egate.java:177)
at org.eclipse.cdt.launch.AbstractCLaunchDelegate.getCProject(AbstractCLaunchDelega
te.java:162)
at com.altera.nj.launch.internal.ui.LaunchUIPlugin.handleDebugEvents(LaunchUIPlugin
.java:243)
at org.eclipse.debug.core.DebugPlugin$EventNotifier.run(DebugPlugin.java:1076)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.debug.core.DebugPlugin$EventNotifier.dispatch(DebugPlugin.java:1108)
at org.eclipse.debug.core.DebugPlugin$EventDispatchJob.run(DebugPlugin.java:344)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Error
Problems occurred when invoking code from plug-in: "org.eclipse.debug.core".
egate.java:177)
te.java:162)
.java:243)
the Microtronix plugin is designed to work with Quartus5.0, to get it working with 6.0 or 6.1 the pathes in the configure.bat file must be changed to point to Quartus6.1.
I only tried 6.0 so far because I have not yet upgraded to 6.1. In 6.1 the path structure has changed significantly, so it could be more effort to get it running on 6.1. Anyway I have changed to build projects on a Linux host in the meantime because the Cygwin environment does not support initramfs
thanks!
i have accomplished the work in Nios6.0, but i think i should do more work in the linux OS. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
