Help with firts NIOS code
Hello, please with my first nios code.
# include "alt_types.h"# include "sys/alt_irq.h"# include "system.h"# include <stdio.h># include <unistd.h>
int main(void){
int a = 1000;
alt_printf("Probehl RESET, uz zase ziju!\n");
while (1){
alt_printf("AHOJ\n");
usleep(500000);
alt_printf("Tady NIOS II!\n");
usleep(500000);
alt_printf("%i\n", a);
return 0;
variable a not print to jtaguart...why?
which Qsys( or maybe SOPC builder ) do you use?
you created it ? or using development kit's Qsys without change?
https://www.altera.com/en_us/pdfs/literature/hb/nios2/n2sw_nii5v2.pdf
See the description of alt_printf() on page 14-78.
Description The alt_printf() function provides a very minimal printf implementation for use with very small applications. Only the following format strings are supported: %x, %s, %c, and %%.
So, probably using "%i" is why it doesn't work for you.
--- Quote Start ---
--- Quote End ---
Yes, problem solved, thanks!
