I'm working on a driver for Phillips PDIUSBD12 for eCos and Nios II. I've come to the point where I have to compile the driver and there are some errors. Configtool can't find the pdiusbd12_regs.h file that I have made. I lies in a directory called pdiusbd12/inc under components and sopc generates a system fine. Configtool finds all the other *regs.h files. How and where does configtool look for these files?
On another subject: Has anyone made a driver for the SPI and PIO components? I need access to these in eCos and the eCos for Nios II doesn't provide the drivers. I might be an easy job writing them, but if anyone already has them finished and working it would have been nice to get them. -Ole Kristian Tørresen链接已复制
1 回复
The *_regs files are included by existing components by adding the required directory to the include path. For example in altera_avalon_uart.cdl you'll find:
cdl_option CYGPKG_ALTERA_AVALON_UART_CFLAGS_ADD {
display "Additional compiler flags"
flavor data
no_define
default_value { "-I'$(SOPC_KIT_NIOS2)'/components/altera_avalon_uart/inc -I$(PREFIX)/include/cyg/hal" }
description "
This option modifies the set of compiler flags for
building the Altera Avalon UART driver.
These flags are used in addition
to the set of global flags."
You just need to do the equivalent for your driver.
