12748 Discussions
How can I go into the "hwselect" window ?
Everyone
When I do the Step3,in which I need to do LinuxHwselect , I cannot make it.
Where can i find the right diretory to go into the following screen:
--- Please select which CPU you wish to build the kernel against:
(1) cpu - Class: altera_nios2 Type: s Version: 5.11
Selection: 1
--- Please select a device to upload the kernel to:
(1) ext_flash
Class: altera_avalon_cfi_flash
Selection: 1
--- Please select a device to execute kernel from:
(1) ext_ssram
Class: altera_avalon_cy7c1380_ssram
(2) ddr_sdram
Class: ddr_sdram_component
I tried the ~/uClinux-dist-test dir ,but I cannot go into.
So I tried ~/uClinux-dist-test/linux2.6.x,and see the correct acreen,
But is it all right???
Thanks!!
I also have met the similar problem today , did not know how to solve.
I have done with it porperly!
[oneuser@RJ uClinux-dist-test]$make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- linux_hwselect SYSPTF=nios_0.ptf
u can find a makefile file in dir "uClinux-dist-test",which contains
info. like this:
linux_xconfig:
KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) xconfig
linux_menuconfig:
KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) menuconfig
linux_config:
KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) config
linux_hwselect:
KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) hwselect
I think it will help you understand the command.
Note: nios_0.ptf must be in the dir /uClinux-dist-test/linux-2.6.x
The steps to rebuild completely from a clean set goes:
make clean
make linux_hwselect SYSPTF=insertyourptfhere.ptf
make
make linux
make image
The previous reply is correct that the PTF file needs to be in the kernel's base directory... in my case the linux-2.6.x directory.
In case you would like to know more about it, the Makfile that eventually gets called to do the actual work is in uClinux-dist-test/linux-2.6.x/arch/nios2nommu/
And the PERL scripts that it uses are in the scripts folder. The script that asks you the questions is hwselect.pl and the script that generates the nios2_system.h file are gen_nios2_system.h.pl.
Your answers to the questions are stored in the hardware.mk file.
make linux_hwselect SYSPTF=~/your_project/your_system.ptf
no need to copy the ptf,
but you should give the path to your ptf.
