12745 Discussions
How can i burn my *.flash file into the flash
I have a *.flash file,now,I want to burn it into the flash at the address of 0x100000 . I use the nios2-flash programmer,the command line is :
nios2-flash-programmer --base=0x100000 --input=altera_nios_dev_board_cyclone_1c20.sof --input=filesys.flash
but the output is:
Aug 6, 2004 10:55:36 AM - (??) nios2-flash-programmer: Launching Quartus Progr
mer to download:
Aug 6, 2004 10:55:52 AM - (??) nios2-flash-programmer: Error opening target ha
ware
Aug 6, 2004 10:55:52 AM - (??) nios2-flash-programmer: Unable to open flash
evice after successfully communicating
with target.
It is likely that you are using a flash-programming FPGA design which
was not created for your target board.
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-b
lt
flash-programming designs pre-built for several development boards. If you
sh
to program flash on your own board, you must first create a flash-programmin
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
what's wrong with me?
You took the same trap as i did..
You have to specify the destination address in the flash while converting from .sof to .flash with
"sof2flash --input=x.sof --output=x.flash --base=0x100000" (or whatever)
At the flash-programmer you have to specify the address where the programmer can find your flash device .
This is 0x800000 on the standard altera nios2 dev boards. I don't know for nios1 designs, but if you open
them in sopc-builder you can extract this value....
nios2_flash_programmer --input=x.flash --sof=altera_nios_dev_board_cyclone_1c20.sof --base=0x800000
i hope this helps...
Thank you very much! I have resloved my problem. Best wishes to you!
