12745 Discussions
How can i handle the pio in uclinux?
I have upload the kernal and filesystem to flash,and the kernal runs very well.Then i build the example 'hello world',it runs very well too.
Now i want to handle the PIO in uclinux,like 'hello led' in nios IDE,i make an application project ,but i can't use the API that ALTERA have provided, like IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE, led).How can i do with it.
On the other hand,can any one tell me where can i download the nios-elf-tools(cross compile tool)in the linux.
you can best use the inl outl or inb outb macro's in linux for accessing the GPIO.
for the crosscompiler you can look for marc&#39;s one but I believe hissite is down at the moment http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
--- Quote Start ---
originally posted by wgoossens@Dec 14 2005, 06:41 PM
you can best use the inl outl or inb outb macro&#39;s in linux for accessing the gpio.
for the crosscompiler you can look for marc&#39;s one but i believe hissite is down at the moment http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11537)
--- quote end ---
--- Quote End ---
Thanks!
Can you tell me more about inl outl .....
try:# man inl
or# man outl
it basicaly reads a long (inl) or a byte (inb) from the port you pass as an argument or writes a long (outl) or a byte (outb).
for example:
outb(inb(GPIO1),GPIO2);
where GPIO1 and GPIO2 are defined as base-addresses of your GPIO components.
reads a byte from the base address of one GPIO and outputs this no a second GPIO.
In the header file...../bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/include/asm-nios2nommu/io.h
There are # define writew(b,addr)
__asm__ __volatile__(
"sthio %0, 0(%1)"
: : "r"(http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif , "r" (addr));
and other application like this.But in my Application Project,when i use writew or other application that has defined in the io.h,there are error undefined reference to `writew&#39;,I have include the header file like this# <asm/io.h>.Can anyone tell me why.
Thanks. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
__KERNEL__ must be defined. If you define this for an application, you&#39;ll likely pull in
other definitions that will cause compile-time problems. I recommend you copy the
macros you need into a header file in your application source tree. It&#39;ll probably save
you some headaches.
--Scott
