12748 Discussions
How do you #include <iostream>
Everytime I put in the statement# include <iostream>
I get an error that says that this file cannot be found... is there anyway to include this file in the NIOSII IDE?
Aydin.
Hi amy35,
in order to do this you have to know where the file is.... First search it with windows (search) or what ever the file is that you need. Then right-click on you project, choose: properties -> C/C++ Build -> (NIOS II COMPILER) General -> Include paths...
Now all you have to do is to include the path to the file and it should work
Good luck....
Danny
The problem with that is that when I do search for IOSTREAM, there are many many IOSTREAM files, most of which, refer to other files themselve... then I get errors regarding those files...
thanks,
Aydin.
Hi Aydin,
suppose you don&#39;t have multiple versions of the ide installed on your pc!? E.g. evaluation version and full version?! We had that problem here at our company. 3 versions installed and gave errors just like you....
good luck
Danny
