12748 Discussions
How does NiosII communicate with other FPGA blocks
I am designing a simple CPU+FPGA application. The FPGA has data bus
for setting registers, one at a time. The data bus includes
inputs: TSData[15:0]
Addr [3:0]
TSDataRdy
TSControl
TSControlValid
output: TCdata[15:0]
TCDataRdy
TCControlRdyToAccpet
So, in SOPC, what's the best way to set up the CPU external interface
for talking to FPGA? Should I use PIO or some exsiting memory controller?
Thanks a lot,
I think you can use user interface logic.
You can write the proper timing logic between avalon and user interface and add to the SOPC.
Maybe a simple question.
How can I make avalon bus available to custom logic module?
Should I choose a component from SOPC builder? Which one?
Thanks!
As I know you need not to add any component called Avalon bus since SOPC Builder by default does all the connections to cpu thru Avalon. You know what all signals you need to connect to Avalon signals. Make an HDL entity where you interface Avalon signals with ur user logic. And add the HDL file of this interface as a new component in SOPC Builder. Read "Avalon Bus Specification" for details on what all signals you require for interfacing with Avalon.
Use component editor (PIO is too simple for most external interfacing). If your interface uses non-Avalon timing add some extra logic to conform to the standard (see the Avalon Bus Spec). If your interface goes off chip and runs at a significantly high speed I recommend re-syncronizing the signals with registers.
Thanks, I found the right document to follow.
Thanks for everyone&#39;s replies. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
