How import project
how import nios project to nios ii 7.2 program when exist two files inside software folder and again run this project.
for example i have project lcd and in lcd folde exist software folder are hello_world_0 and hello_world_0_syslib how import this project and run to board
please i'm need this info.
any one know how please answer me.
thank you for all.
where your answers please I need this idea.
Could you rewrite your post please ? I don't understand, and neither the others.
If you use Nios II IDE on File in menu choose import -> Altera Nios II -> Existing Nios II IDE project into workspace ... there you can specify the path to your software project. You must include the hello_world_0 and hello_world_0_syslib folders in nios ii ide.
hank you for replay Mr zodrax (http://www.alteraforum.com/forum/member.php?u=28133
but regarding library propareites where foun in niosii 9.1 where small size characters that exist in nios ii 7.2 i found 1 error when build project in nios 9.1 please i am very needed this idea.
thank you for all.
