- Using Altera NIOS II IDE 5.0. How to build applications for uClinux on Stratix II (EP2S60_ES). What are these steps ?
- How about building without NIOS II IDE 5.0, use what tool ? - How to write own driver for uClinux on Stratix II (EP2S60_ES). ? - from the Microtronix's Distribution. How to re-compile the kernel for Stratix II (EP2S60_ES) ? Thank you all very much !Link Copied
A: Follow the Application Tasks section in the reference guide... - How about building without NIOS II IDE 5.0, use what tool ? A: After creating the initial Application Project, you can use the Nios II SDK Shell, cd $ECLIPSE_WORKSPACE/<project> and run make from there. - How to write own driver for uClinux on Stratix II (EP2S60_ES). ? A: Writing a driver for uClinux is the same as writing a driver for any Linux distribution, please take a look online for good documentation. It's there. The kernel source can be found through the Nios II SDK shell using the following command: cd $KERNEL_PLUGIN/linux-2.6.x - from the Microtronix's Distribution. How to re-compile the kernel for Stratix II (EP2S60_ES) ? A: If the Quick Start Guide doesn't answer that question then you'll need to be more specific. Are you using a different hardware design that you need to compile a kernel for?- Mark as New
Dear Ken !
thank you very much for your answer ! Please help me this problem: We are using altera cyclone1c12 eval (using on-board Flash chip)...., NIOS IDE 5.0 How to write a file When running a C application in uClinux ? fp=fopen(myfile,"r") works well but an error occurs when I use fp=fopen(myfile,"w") Please follow the link to see the images : problem image (http://img.photobucket.com/albums/v604/bebechance/problem.jpg) http://img.photobucket.com/albums/v604/bebechance/problem.jpg There are 2 possible problems for this error : 1. linux_time_limited.sof doesn’t support writing file 2. The program is running on sdram but the file (output_filename) is written to Flash. We already knew that we cannot write to Flash by C functions such as fprintf ,fwrite ,…. To do that , we must use some scripts : nios2-flash-programmer , …… Is this related to RO readonly.....? If it is the reason , then the uClinux FileSystem is useless. What do you think ?- Mark as New
Hi OneNet,
there is one more explanation to your problem, which seems to be the most possible : 3. Your filesystem is readonly. If you want a r/w filesystem you can use ramfs (volatile, in ram) or jffs2 (non-volatile, in flash). If you use the default filesystem delivered with Microtronix distribution, you probably have some part of the system mounted as ramfs (/var and /tmp I think, check by executing mount without option to see what is mounted and where). You should try to create you r/w file in one of those directories, it should work. Hope it helps Pod- Mark as New
Dear cetic !
I'm trying your way. I could create a new folder in /var successfully.Hopefully, your answer is helpful for anyone who is having this problem. Thank you very much !
