12748 Discussions
How to compile/load uClinux to 2s60 demo board?
I just downloaded the latest distribution of uClinux and installed it on my pc. I am also running into the same problem as a few others have -- namely there is no "linux" subdirectory in the ..\altera\kits\nios2\examples\verilog\niosII_stratixII_2s60_ES directory.
One other "issue" though is that when I get to the point of trying to configure the kernel, I right click on the created project and I don't see the "Configure Kernel" option.
I have Quartus II 4.2 service pack# 1 loaded, with the Nios 1.1 distribution.
Bob
Bob,
I've asked the same question a time ago, and in the meantime I figured
it out myself.
Make a copy of the EP2S60 full featured directory and start the SOPC builder
in this directory. Add a CF component to the design and compile the design.
You can use the new ptf file to compile the Filesystem and Kenel.
It already works with my EP2S60 board.
Good luck ...
Digi
BTW seen that problem more than one time...
Try to start the IDE from within SOPC builder.
Sometimes this helps ...
Digi
I have also got a STRATIX II board.
Yust run quartus en open a example desing.
Then run SOPC builder ( double click on the symbol block ) then add / remove components a you like.
then run sopc builder and exit. Quartus ask to update the block, do that.
Then compile your compleet desing with quartus. You see that your *.sof file ha been changed.
Now used this new desing for reference when you create a new kernell/filesytem in the IDE program
I must be doing something extremly wrong....
I copied over the full_featured structure into a "linux_full_featured" directory.
Tried then to set up cf...but noticed that the ext_flash was already defined in
the system.
Tried to rebuild and then come into the NIOS IDE. Still cannot select/right click
on my "kernel" design and get the Configure Kernel option to display.
I'm wondering if I need to contact Altera directly about this. Not thrilled to
contact Microtronix about it; seems that they want $300/incident to look at this...
Bob,
the extern flash is the AM29LV128 mounted on your development kit board.
The CF component is needed for the external sandisk compact flash card.
Digi
To configure the kernel, make sure you're in the Navigator perspective in the Nios II IDE. Look for tabs along the bottom of the tree view on the left side of the window. You're probably in the C/C++ Projects perspective now.
