12745 Discussions
How to deal with the route in Linux
the next figure is my network
----<--Extern Network(ADSL module)(IP base : 192.168.1.1 netmask 255.255.255.0 -->
|______><Route (IP base 192.168.2.1 netmask 255.255.255.0)>-->
___><my PC IP : 192.168.2.102 netmask 255.255.255.0>
|_><my EP2C35 Board>
NOW, I have install a FTP seriver in my Pc. I want to transfer a file from the pc to my board
(ep2c35 dev kit)
so first i config the IP
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
# ifconfig eth0 192.168.2.12 eth0
eth0:PHY 100BaseT
eth0:PHY Full Duplex[/b]
--- Quote End ---
ok I find it can&#39;t connect when I ping my PC
so i check the information of route.
--- Quote Start ---
# route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.2.0     *               255.255.255.0   U     0      0        0 eth0
127.0.0.0       *               255.0.0.0       U     0      0        0 lo
I don&#39;t konw how to change  the IP(192.168.2.0) of eth0 to 192.168.2.1)
so i had to add a route .but i got a errors . # route add 192.168.1.1 gw 192.168.2.1 netmask 255.255.255.0 eth0
route: netmask 000000ff and host route conflict# [/b]
--- Quote End ---
if i don&#39;t care the netmask . the netmask will become to "255.255.255.255".
--- Quote Start ---
# route add 192.168.1.1 gw 192.168.2.1 eth0# route
192.168.1.1     192.168.2.1     255.255.255.255 UGH   0      0        0 eth0
127.0.0.0       *               255.0.0.0       U     0      0        0 lo# [/b]
--- Quote End ---
can you tell me ! how to deal with it . thanks !
do you config your board as following?
you can use "ifconfig eth0 192.168.2.12".
if the two device in the same subnet. The ip pocket won&#39;t transmit through the route
enable this in in networking options of kernel config, and read the help of this , about ip forwarding,
[* ] IP: advanced router
HI hippo
I have select the next config
but now i find a strange things . when i use the next command in my PC (win-xp)
--- Quote Start ---
C:\Documents and Settings\alexliu>ping 192.168.2.12
Pinging 192.168.2.12 with 32 bytes of data:
Reply from 192.168.2.12: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.2.12:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms[/b]
--- Quote End ---
but I use the next command in my Board (EP2C35)
--- Quote Start ---
# ping 192.168.2.102
PING 192.168.2.102 (192.168.2.102): 56 data bytes
--- 192.168.2.101 ping statistics ---
6 packets transmitted, 0 packets received, 100% packet loss# ping 192.168.2.1
PING 192.168.2.1 (192.168.2.1): 56 data bytes
84 bytes from 192.168.2.1: icmp_seq=0 ttl=128 time=10.0 ms
84 bytes from 192.168.2.1: icmp_seq=1 ttl=128 time=0.0 ms
84 bytes from 192.168.2.1: icmp_seq=2 ttl=128 time=0.0 ms
84 bytes from 192.168.2.1: icmp_seq=3 ttl=128 time=0.0 ms
84 bytes from 192.168.2.1: icmp_seq=4 ttl=128 time=0.0 ms
--- 192.168.2.1 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.0/2.0/10.0 ms[/b]
--- Quote End ---
so I cann&#39;t find the reason . why I can connect the router(192.168.2.1) but when i connect my pc(192.168.2.102) ,i cann&#39;t connect it .
but you said your PC&#39;s IP is 192.168.2.102 ? not 192.168.1.101?
--- Quote Start ---
originally posted by hippo@Mar 15 2006, 10:03 AM
but you said your pc&#39;s ip is 192.168.2.102 ? not 192.168.1.101?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13437)
--- quote end ---
--- Quote End ---
sorry ,because my PC &#39;s IP be assign by the route(192.168.2.1), so it maybe beccome to 192.168.2.101.
I don&#39;t Know Why can&#39;t ping the PC , I thinks the network should be can work.
ifconfig eth0 192.168.2.12 route add default gw 192.168.2.1
Now I input the next command
--- Quote Start ---
127.0.0.0       *               255.0.0.0       U     0      0        0 lo# ifconfig eth0 192.168.2.12
Heth0:PHY 100BaseT
eth0:PHY Full Duplex# route -n
192.168.2.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
127.0.0.0       0.0.0.0         255.0.0.0       U     0      0        0 lo[/b]
--- Quote End ---
i add the route
--- Quote Start ---
# route add default gw 192.168.2.1# route -n
0.0.0.0         192.168.2.1     0.0.0.0         UG    0      0        0 eth0[/b]
--- Quote End ---
when i input the ping
--- Quote Start ---
--- 192.168.2.102 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss# ping 192.168.2.1
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.0/3.3/10.0 ms# [/b]
--- Quote End ---
in my computer
I input the ipconfig
--- Quote Start ---
Ethernet adapter &#26412;&#22320;&#36830;&#25509;:
        Connection-specific DNS Suffix  . : private
        IP Address. . . . . . . . . . . . : 192.168.2.102
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        Default Gateway . . . . . . . . . : 192.168.2.1[/b]
--- Quote End ---
so I ping the board
--- Quote Start ---
Reply from 192.168.2.12: bytes=32 time=1ms TTL=64
    Minimum = 0ms, Maximum = 1ms, Average = 0ms[/b]
--- Quote End ---
it very strange . I don&#39;t know how to deal with the problem . pls help me !
thanks !!!
Maybe it is the firewall on your xp, that blocks the ping.
Can you ping outside your router from nios2?
--- Quote Start ---
Can you ping outside your router from nios2?[/b]
--- Quote End ---
what&#39;s means?
I can ping outside in NIOS2
--- Quote Start ---
# ping 192.168.2.1
3 packets transmitted, 3 packets received, 0% packet loss[/b]
--- Quote End ---
but it only ping the 192.168.2.1 or
when we have a another pc in the network(ip:192.169.2.100)
--- Quote Start ---
# ping 192.168.2.100
PING 192.168.2.100 (192.168.2.100): 56 data bytes
84 bytes from 192.168.2.100: icmp_seq=0 ttl=128 time=0.0 ms
84 bytes from 192.168.2.100: icmp_seq=1 ttl=128 time=0.0 ms
--- 192.168.2.100 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 0.0/0.0/0.0 ms# [/b]
--- Quote End ---
my pc maybe have some problem.
I will check it !
