I use “Reprogramming the Flash Memory" to restore factory_recovery.But it plays
NOTES: Restoring flash has not changed the network settings for your kit. However, if the factory program does not find valid network settings, the user will be automatically instructed as to how to reset them. Also, Restoring flash has not changed your \"User\" flash region. Thank you. How can I erase the "User" flash region.Link Copied
If you run the memtest example software template, there's a "hidden" feature which should allow you to erase your entire flash device. Just type 'e' at the main menu (I believe, though it could be in one of the sub-menus.
Cheers, - slacker- Mark as New
Thank you you can answer my question.I erase flash successfully.
Thank you very much.
