12748 Discussions
How to implement my own bootloader
My system doesn't use CFI Flash but SPI Flash, so I have to creat my own bootloader to read code from SPI Flash to SDRAM.
Now, I have implemented a bootloader code which is located in an onchip memory and it can work fine to read data from SPI Flash to SDRAM.
But I have a important question:
Before reading data from SPI Flash to SDRAM, I should initialize the SPI Flash with my Main Code, but how can I get Main Code???
As I know, NiosII IDE will create *.elf for you, but this file will contain many more redundant code which is for programming CFI Flash. What I need is only the following sections:
.exceptions, .rodata, .rwdata and .text
Anyone help?
Thanks very much!
Hi David,
> sections:
Use nios2-elf-objcopy.
--Scott
Hi Smcnutt:
I'm not familiar with TCL tools, in fact, I never use them.
Could you teach me how to use nios2-elf-objcopy and what will I get?
Or, if there is any document related to TCL tools, pls let me know!
Thanks very much!
objcopy is part of binutils -- use it from a command shell prompt.
Try:
$ nios2-elf-objcopy --help
You can also review documents\gnu-tools\binutils\binutils.html in your
nios2 installation directory.
--Scott
Dear Scott:
Thanks very much!
Everything is OK, now! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
David
