Hi,everyone. I want to implement a router using eCos. I have already written the device driver for eth1(my own ethernet device) and add this device to component library(eth0 is LAN91C111). I have also added this device in configtool. I add the net package in configtool. What should I do next? What else package must be added to my system in configtool? Or should I write something?
P.S. What can I do to make sure my own device driver works fine? Thank you very much for any kinds of help!Link Copied
--- Quote Start --- originally posted by diviner524@Apr 11 2006, 01:10 AM hi,everyone. i want to implement a router using ecos. i have already written the device driver for eth1(my own ethernet device) and add this device to component library(eth0 is lan91c111). i have also added this device in configtool. i add the net package in configtool. what should i do next? what else package must be added to my system in configtool? or should i write something?
p.s. what can i do to make sure my own device driver works fine?
thank you very much for any kinds of help!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14228)
--- quote end ---
--- Quote End --- I think you have to write your own componenet for the router. There is no readymade component available router.
