12608 Discussions
How to know the code size ?!
hey mates
My questions are :
I need to use the OnCMemo for another purpose so I should know the space occupied by the code !
How do I know my code size after building ?
How to know the beginning and end @ of the code downloaded in the OnCMemo?
thnx
what is OnCMemo?
--- Quote Start ---
what is OnCMemo?
--- Quote End ---
Sorry ! On chip memory
When you compile with Eclipse in output window there is .elf size
So the reset @ of my cpu is the starting @ of the code ? the end is the start + the size of elf ?
You can run nios2-stackreport on your *elf file. It should give you the code size.
For example:
$ nios2-stackreport hello_world.elf
Info: (hello_world.elf) 29 KBytes program size (code + initialized data).
Info: 92 KBytes free for stack + heap.
It shows me that the program size is 29KBytes. I have a 128KByte onchip-memory, thus it reported I have 92KBytes for stack and heap.
You can reduce the size if you are sharing the onchip memory via nios2-bsp-editor/linker section.
Or you can just split out the onchip memory to smaller size, ie 2 64KByte memory.
