How to modify this HDL code
module TV_to_VGA (      OSC_27,      RESET,    VGA_BLANK,      VGA_SYNC,      VGA_CLOCK,      VGA_HS,    VGA_VS,      VGA_R,    VGA_G,    VGA_B,    TD_D,    TD_HS,    TD_VS ); input      OSC_27; input      RESET; output    VGA_BLANK; output      VGA_SYNC; output      VGA_CLOCK; output      VGA_HS; output    VGA_VS; output      VGA_R; output    VGA_G; output    VGA_B; input    TD_D; input    TD_HS; input    TD_VS; wire     Y;       //4:4:4 Y wire     Cb;      //4:4:4 Cb wire     Cr;      //4:4:4 Cr wire mTD_HSx2; itu_r656_decoder U1 (     .CLOCK(OSC_27),  //system clock     .TD_D(TD_D),    //4:2:2 video data stream  .TD_HS(TD_HS),  //Decoder_hs     .TD_VS(TD_VS),  //Decoder_vs         .Y(Y),        //4:4:4 Y     .Cb(Cb),          //4:4:4 Cb     .Cr(Cr),          //4:4:4 Cr    .HSx2(mTD_HSx2),           .blank(VGA_BLANK) ); YCbCr2RGB U2(         .Red(VGA_R),     .Green(VGA_G),     .Blue(VGA_B),     .iY(Y),     .iCb(Cb),     .iCr(Cr),           .iRESET(!RESET),     .iCLK(OSC_27)     ); `include "VGA_Param.h" reg  L_COUNTER;//<< reg  RL_COUNTER;//<< wire  sync_reset=(RL_COUNTER==9)?1:0; reg      sync_en;//<< reg      delay;//<< reg      H_Cont; reg      V_Cont; reg    oVGA_H_SYNC; reg    oVGA_V_SYNC; reg    Pre_HS; reg    Pre_VS; reg    mACT_HS; reg    mACT_VS; always@(posedge OSC_27 or negedge sync_en)//<< begin     if(!sync_en)//<<     begin  Pre_HS  <=    0;  mACT_HS  <=    0;  H_Cont  <=    0;  oVGA_H_SYNC    <=    0;     end     else     begin  Pre_HS    <=    mTD_HSx2;  if({Pre_HS,mTD_HSx2}==2&#39;b10)  mACT_HS    <=    1;  if(mACT_HS)  begin      //    H_Sync Counter      if( H_Cont < 852 )      H_Cont    <=    H_Cont+1;      else      begin    H_Cont    <=    0;    mACT_HS    <=    0;      end      //    H_Sync Generator      if( H_Cont < H_SYNC_CYC )      oVGA_H_SYNC    <=    0;      else      oVGA_H_SYNC    <=    1;  end  else  begin      oVGA_H_SYNC    <=    0;      H_Cont  <=    0;  end     end end always@(posedge OSC_27 or negedge sync_en)//<< begin     if(!sync_en)//<<     begin  Pre_VS  <=    1;  mACT_VS  <=    0;  V_Cont  <=    0;  oVGA_V_SYNC    <=    0;     end     else     begin  Pre_VS    <=    TD_VS;  if({Pre_VS,TD_VS}==2&#39;b01)  mACT_VS    <=    1;  if( (H_Cont==1) && mACT_VS)  begin      //    V_Sync Counter      if( V_Cont < 524 )      V_Cont    <=    V_Cont+1;      else      V_Cont    <=    0;      //    V_Sync Generator      if(    V_Cont < V_SYNC_CYC )      oVGA_V_SYNC    <=    0;      else      oVGA_V_SYNC    <=    1;  end     end end assign    VGA_HS  =    oVGA_H_SYNC; assign    VGA_VS  =    oVGA_V_SYNC; assign    VGA_SYNC    =    1&#39;b0; assign    VGA_CLOCK    =    OSC_27; //>>lock detector always @(posedge TD_HS) begin if (TD_VS) L_COUNTER=0;          else L_COUNTER=L_COUNTER+1; end       always @(posedge TD_VS) begin  RL_COUNTER=L_COUNTER;//1714 end     always@(negedge sync_reset or posedge TD_VS) begin if (!sync_reset)     delay=0;    else if (delay < 250)  delay=delay+1; end     always@(negedge sync_reset or negedge TD_VS) begin if (!sync_reset)      sync_en=0; else if (delay < 100)    sync_en=0;    else     sync_en=1; end //<< endmodule
This section of code is for NTSC standard,now I want to change it for PAL standard.
I have made clear the succession of the two standards&#12290;NTSC delivers 525 lines of resolution at 60 half-frames per second, and PAL delivers 625 lines at 50 half-frames per second.
Otherwise, the length of odd and even fields for NTSC are all 9,but for PAL,the odd field is 24 and even field 25.
How to modify this code for PAL standard?
Here is the succession for PAL.
http://www.freefpga.com/bbs/upload/200671593647-137.gif
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif ,I can decode the Pal signal based on the de2_tv projection, but this is not the color.
i have the same question! how can convert pal to ntsc using fpga? who have the code? thanks!
