12620 Discussions
How to porting u-boot to my own board?
Hello, everyone
I want to use u-boot on my board. I have two questions.
1. Before I use u-boot on my board, I just try to compile u-boot first. So, I follow the readme file.
I use
make PK1C20_config
make all
But there have errors.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
In file included from /usr/include/sys/unistd.h:9,
                from /usr/include/unistd.h:6,
                from img2srec.c:61:
/usr/include/sys/types.h:106: conflicting types for `int8_t&#39;
/usr/include/stdint.h:38: previous declaration of `int8_t&#39;
/usr/include/sys/types.h:108: warning: redefinition of `int16_t&#39;
/usr/include/stdint.h:39: warning: `int16_t&#39; previously declared here
/usr/include/sys/types.h:110: warning: redefinition of `int32_t&#39;
/usr/include/stdint.h:40: warning: `int32_t&#39; previously declared here
/usr/include/sys/types.h:112: warning: redefinition of `int64_t&#39;
/usr/include/stdint.h:45: warning: `int64_t&#39; previously declared here
make[1]: *** Error 1
make[1]: Leaving directory `/cygdrive/d/My_Project/MtxCyclone_uBoot/BootLoader/u-boot-1.1.3/tools
make: *** [tools] Error 2[/b]
--- Quote End ---
I search the forum and find the answer given by smcnutt.
--- Quote Start ---
This looks like the sources directly from sourceforge.net ... this tree assumes you
have an appropriately configured native gcc and shell environment -- which
doesn&#39;t come with the nios2 toolchain 8-P The easiest thing to do is get the source
tree from http://www.pysent.com/download (http://www.pysent.com/download) -- this tree has certain "nips & tucks"
made to build cleanly with the default nios2 toolchain (under cygwin) -- and it&#39;s
more up-to-date than the sourceforge tree (WRT Nios-II, the sourceforge tree
has been lagging by several months).[/b]
--- Quote End ---
But I can not access the web link. Can give me the right link or the files?
2. If I want use u-boot on my MtxCyclone Board, how can I do?
Just what should I do according to the PK1C20.h?
Can give me more information or detailed steps than readme file?
Thank you very much,
LiangYi
Hi LiangYi,
The link is correct and working. Sadly, the problem is probably because you are in China,
and your government prevents your free access to the Internet.
It would be a pleasure to send you the source code. Please send me a PM with a valid
email address that can accept a 1.6 MB attachment. And please feel free to distribute the
code among your colleagues.
--Scott
Hi Scott,
Thank you very much.
Here is my email address
liangyi@vip.sohu.net
Hello Scott,
I modify some code according to my board and U-boot runs on my board. It runs in sdram.
--- Quote Start ---
U-Boot 1.1.3 (Sep 14 2005 - 16:46:34)
CPU?nbsp; : Nios-II
SYSID : 3ef94735, Wed Sep 14 08:39:42 2005
BOARD : Microtronix MCK-1C20
*** Warning - bad CRC, using default environment
==>[/b]
--- Quote End ---
But I still have some questions.
1. When I change the TEXT_BASE in config.mk, u-boot can not be made.
Can you tell me detailed about TEXT_BASE, and how to set it?
2. First, I creat a new directory to store the new platform.
make xxxx_config --------OK
make ---------error
--- Quote Start ---
make -C &#39;dirname board/microtronix/mtxkit1c20/libmtxkit1c20.a&#39;
make[1]: Entering directory &#39;/cygdrive/....../u-boot/board/microtronix/mtxkit1c20&#39;
make[1]:*** No rule to make target &#39;mtxkit1c20.c&#39;, needed by &#39;.depend&#39;. Stop.
make: *** [board/microtronix/mtxkit1c20/libmtxkit1c20.a] Error 2[/b]
--- Quote End ---
But when I put the platform under altera directory, u-boot is made OK.
Why?
3. I run saveenv and re-run, but the warning still appear. Why?
Thank you,
LiangYi
Hi LiangYi,
I don&#39;t understand what you mean by "u-boot can not be made" ... please describe what
you observe. Does the make fail? Does the link fail?
TEXT_BASE is set to the address where the .text section is located. This is the section
that contains all of your code. In u-boot you would typically set this to a location at the
top of your sdram (so the bottom of your sdram is available for a kernel).
> Why?
Make is looking for mtxkit1c20.c and can&#39;t find it. Check your make target in the top level
Makefile -- and always make distclean after moving stuff around ... you might have some
artifacts (like old .depend files) in your source tree. Your top level target should call mkconfig
with the appropriate arguments:
mkconfig BOARD ARCH CPU DIR VENDOR
Based on your post, you should have:
mkconfig MTXKIT1C20 nios2 nios2 mtxkit1c20 microtronix
The saveenv command writes your environment variables to a non-volatile
memory ... which is normally a parallel flash device. If you see the warning after
running saveenv, the save operation failed. This is usually because you don&#39;t
have your envirnonment setup properly ... or your flash implementation is broken.
Please let me know the following:
What type of flash are you using? (type and geometry)
What is its base address?
What is the value assigned to CFG_ENV_ADDR?
--Scott
Hi Scott,
--- Quote Start ---
you observe. Does the make fail? Does the link fail?[/b]
--- Quote End ---
Sorry, somewhere I make a mistake. I recheck and can build correct.
--- Quote Start ---
Make is looking for mtxkit1c20.c and can&#39;t find it¡­¡­¡­..[/b]
--- Quote End ---
Yes, the name of .c file is inconsistent with top-level Makefile.
--- Quote Start ---
What is the value assigned to CFG_ENV_ADDR?[/b]
--- Quote End ---
My flash is AM29DL323GB-90EI. 2M*16bit flash
Base Address is 0x0.
I find that CFG_ENV_ADDR is define in MTXKIT1C20.h file(platform description file).# define CFG_ENV_ADDR (CFG_RESET_ADDR + CFG_MONITOR_LEN)# define CFG_RESET_ADDR 0x00000000 /* Hard-reset address */# define CFG_MONITOR_LEN (256 * 1024) /* Reserve 128k */
I do not know clearly what files I need to have and how to correct them. So my board can be initialized OK.
My system now just include NIOS2/s, SDRAM, FLAHS, EPCS4, UART, JTAG-UART, sysid and system_timer.
LiangYi
Another three questions.
1. Now I can run u-boot in sdram, but how can I know the hardware in my system are being initialized proper.
2. I have build vmlinux.bin. I want to run it in sdram through u-boot, how to do?(I find mkimage can not be used in my u-boot directory.)
3. Because I do not know clearly the detail of the nios2 application execution(for example--helloworld).
So I want to know it.
cpu initial->hardware initial->jump main app. What files(.S, .h, .c) do this involve? Which reference of nios2 is helpful to me to know this.
Thank you,
LiangYi
Hi LiangYi,
Great! :-)
Test it ... this is your responsibility ;-) u-boot only initializes what it uses:
serial, timer, epcs. If you have custom logic or other devices you want to initialize,
you can define CONFIG_BOARD_EARLY_INIT_F and implement the routine
board_early_init_f() -- which gets called very ... well ... early ... in the init
sequence.
If you want to compress:
$ gzip --best -c vmlinux.bin > vmlinux.gz
$ mkimage -A nios2 -O linux -T kernel -C gzip -n "Microtronix uClinux 1.4" -d vmlinux.img
-a <whatever> -e <whatever>
Then put the vmlinux.img file in flash somewhere (e.g. 0x200000) and from u-boot run:
==> bootm 200000
You have two choices: port it to cygwin or get it from the psyent download page.
-- I&#39;ll just send mkimage to you via email.
u-boot has something similiar to the hal ... since you can write what u-boot
refers to as "standalone applications" or "mini-applications". You need to read the
top level README file and docs/README.standalone. I tested hello world and it
works fine (now that several bugs are fixed).
As for the whole u-boot startup sequence, you&#39;ll have to use the force here ;-)
Life starts in cpu/nios2/start.S and quickly jumps into lib_nios2/board.c.
I hope this was helpful.
--Scott
Hi LiangYi,
Sorry, I missed the info in your earlier post:
Ok. So you have several choices here. You can implement your own flash.c file (see other
boards for example), or you can use the u-boot CFI flash driver. To implement your own
flash driver, just copy an existing flash.c file that supports the AM29DL323 and add it to
your board directory. The RPXClassic, RPXlite_dw, esd/common trees have flash.c files
that support your device. You can customize your own flash.c files as you like.
The other option is to use the u-boot CFI flash driver (with fixes for avalon bus). The
(patched) driver was reported to work fine on the UP3 board. The CFI driver increases the
size of your u-boot image -- but should work with all CFI-compliant flash devices -- I&#39;ll send
you the patch.
To get started, the easiest thing to do is enable CFI, once this is (mostly) working you can apply
the patch, customize, whatever you like. Remove any board-specific flash routines from your
build, then configure for CFI. Here&#39;s a starting point:
# define CFG_FLASH_CFI_DRIVER# define CFG_MAX_FLASH_SECT 71 /* Max# sects per bank */# define CFG_MAX_FLASH_BANKS 1 /* Max# of flash banks */# define CFG_FLASH_CFI
> can be initialized OK. My system now just include NIOS2/s, SDRAM, FLAHS, EPCS4, UART,
u-boot will initialize epcs4 (if enabled), the UART _or_ JTAG UART (but not both ... it only
touches the device that you specify as the console), and the timer. The flash is scanned
based on the flash driver you choose (normally your flash.c fle). The SDRAM and SYSID
do not require initialization.
--Scott
Thank you Scott,
So many to do according to your apply.
I will test step by step.
If something is wrong, I will paste.
Thank you,
LiangYi
Hi Scott,
I am in trouble now.
1. My u-boot flash driver
You said I can use flash.c. So, I browse flash.c(include /common/flash.c). I found AMDLV065D.c just have both parts of two flash.c files. So, I think I can change AMDLV065D.c to my use.
I change CFG_MAX_FLASH_SECT and CFG_MAX_FLASH_BANKS(in board.h), change flash_id = FLASH_MAN_AMD + FLASH_AMDL323B. Is it right?
2. In order to Programming U-Boot into Flash, I add 1M sram.
But, when do as USING.TXT, it appears
--- Quote Start ---
System Analyzer for Nios® II Processor
Serial number
Version 1.9.4 build 0
Copyright © 1998-2004 First Silicon Solutions, Inc.
Communication port must be specified.
Use openport <port> to configure the communication port
cd d:/My_Project/MtxCyclone_uBoot/BootLoader/u-boot-src/u-boot
1> halt
Communication has not been established with remote unit.
2> load bin 0x00600000 u-boot.bin
3>[/b]
--- Quote End ---
Why?
3. I use NIOS_IDE Flash Programmer to download u-boot to my flash. After that I run # nios2-terminal
Nothing happen, I do know why?
LiangYi
Hi LiangYi,
I was referring to the flash.c files found in most board-specific trees. Most of the supported
boards (see the boards directory tree) contain a file named "flash.c" -- this is a common
convention in u-boot. The boards that show support for the AM29DL323 are for example,
RPXClassic, RPXlite_dw, and some of the esd boards (esd/common). Those trees will
probably have the code you can use.
># nios2-terminal
You probably still have the flash programmer design loaded. Try reloading your application sof.
This is probably your problem ;-)
--Scott
Hi Scott,
I have tested cfi_flash.c.
I add<div class='quotetop'>QUOTE </div>
--- Quote Start ---
#define CFG_FLASH_CFI_DRIVER# define CFG_MAX_FLASH_SECT 71 /* Max# sects per bank */# define CFG_MAX_FLASH_BANKS 1 /* Max# of flash banks */# define CFG_FLASH_CFI[/b]
--- Quote End ---
to my board.h file. When I build u-boot, it has error in function flash_init().
--- Quote Start ---
cfi_flash.c:343: undefined reference to &#39;monitor_flash_len&#39;[/b]
--- Quote End ---
Is monitor_flash_len the u-boot image file size?
What can I do about it?
Furthermore, My flash is 16-bit width, should I define FLASH_CFI_16BIT in my board.h.
LiangYi
Hi LiangYi,
Did you modify cfi_flash.c? My version has no reference to monitor_flash_len at line 343 -- it shows
up in the statement at line 348. Just as a sanity check, your code should look like this:#if (CFG_MONITOR_BASE >= CFG_FLASH_BASE)        && (CFG_MONITOR_BASE <= CFG_FLASH_BASE + CFG_FLASH_SIZE)        flash_protect (FLAG_PROTECT_SET,                        CFG_MONITOR_BASE,                        CFG_MONITOR_BASE + monitor_flash_len  - 1,                        flash_get_info(CFG_MONITOR_BASE));# endifCheck your config macro definitions. This should not even be compiled, unless you are trying
to run u-boot out of flash.
No, it is defined in include/flash.c. The CFI code determines the width automatically.
--Scott
Hi Scott,
I have added cfi_flash.c to my u-boot, re-compiled u-boot and it can run in sdram.
Then, I download the u-boot to my flash at 0x0 using Flash-Programmer. I reload the app sof file, open NIOS2-SDK Shell, run nios2-terminal. Nothing happen.
I think that nios2-terminal start with jtag-uart, but not from uart. I do not know how to do next step?
Give some info.
Thank you.
LiangYi
Hi LiangYi,
Great!
How did you create the flash file? Typically, you should do the following:
$ elf2flash --base=0x0 --end=0x7fffffff --input=u-boot --outfile=u-boot.flash --flash=<Uxx>
$ nios2-flash-programmer --base=0x0 --input=u-boot.flash --sof=<xxx.sof>
When you run out of sdram, do you use the jtag uart ... and did you see the command prompt?
If everything works with download/go to sdram, you most likely have a problem with the u-boot
image stored in flash (either the flash file is incorrect ... or flash memory is not correct).
--Scott
Hi Scott,
A strange problem, so annoyed.
In Nios SDK Shell, I type command you say under my u-boot directory.
$elf2flash --base=0x0 --end=0x1fffff --input=u-boot --output=u-boot.flash --flash=U20
Respond : elf2flash: No reset address provided on the command line, and none found in the ELF file
Then, I add.
$elf2flash --base=0x0 --end=0x1fffff --input=u-boot --output=u-boot.flash --flash=U20 --reset=0x0
Respond: elf2flash: Boot copier file name required, error generating Flash file, exiting
I redo, add
$elf2flash --base=0x0 --end=0x1fffff --input=u-boot --output=u-boot.flash --flash=U20 --reset=0x0 --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec
Respond: elf2flash: read error: File not found: c:/altera/kits/nios2/component/altera_nios2/boot_loader_cfi.srec
elf2flash: Error reading boot copier
Does elf2flash need all parameters?
My path C:\altera\kits\nios2\components\altera_nios2\boot_loader_cfi.srec is right, but elf2flash can not find the file. Why?
LiangYi
Hi LiangYi,
elf2flash is appropriate if you boot from an epcs, ... sorry for misleading you. When you are using
parallel flash with u-boot, bin2flash is what you want (since the u-boot make will generate a
binary image). E.g.:
$ bin2flash --base=0x0 --location=0x0 --flash=U20 --input=u-boot.bin --output=u-boot.flash
u-boot does not require the boot copier ... it will relocate itself to its run-time address.
--Scott
Hi Scott,
It make me headache.
My Flash progrmmer (Microtronix official Providing) can not work under Nios SDK Shell. But it works fine in Nios IDE.
I re-generate my flash-programmer design, but the same.
The infomation under Nios SDK Shell is (I copy .sof to u-boot directory)
--- Quote Start ---
> $ nios2-flash-programmer --base=0x0 --input=u-boot.flash --sof=mtx_nios_dev_board_cyclone_1c20.sof
nios2-flash-programmer: Launching Quartus Programmer to download:
      mtx_nios_dev_board_cyclone_1c20.sof (here download to my FPGA)
Send <64> failed.
Unable to synchronize with target.
......nios2-flash-programmer: Error opening target hardware[/b]
--- Quote End ---
OR
--- Quote Start ---
......nios2-flash-programmer: Unable to open flash device after successfully communicating with target.[/b]
--- Quote End ---
Is there any difference between nios2-flash-programmer in Nios SDK Shell and Flash Programming in Nios IDE?
LiangYi
It is the same application ... but the parameters may be different.
--Scott
Hi Scott,
--- Quote Start ---
Send <64> failed.
--- Quote End ---
This is the error infomation displayed in Nios SDK Shell. But It runs OK in Nios IDE.
I do not know what is wrong. Have you ever seen this problem?
I will try again.
LiangYi
