12748 Discussions
How to store the data from the Nios II to the PC?
I used NiosII as a processor for vehicle detection and I want to send the result to my PC's harddisk. How to implement it? I try to use file system, but I cannot make it. It seems the NiosII IDE ONLY deal with the data on board, right?
--- Quote Start ---
originally posted by liyasi@Mar 27 2006, 11:00 AM
i used niosii as a processor for vehicle detection and i want to send the result to my pc's harddisk. how to implement it? i try to use file system, but i cannot make it. it seems the niosii ide only deal with the data on board, right?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13811)
--- quote end ---
--- Quote End ---
May be use uart for send data to PC?
Of course, you need the teminal app on your PC and Nios that realize X-modem(Y-modem?) for example.
--- Quote Start ---
originally posted by slava+mar 27 2006, 04:09 pm--><div class='quotetop'>quote (slava @ mar 27 2006, 04:09 pm)</div>
--- quote start ---
<!--quotebegin-liyasi@Mar 27 2006, 11:00 AM
i used niosii as a processor for vehicle detection and i want to send the result to my pc&#39;s harddisk. how to implement it? i try to use file system, but i cannot make it. it seems the niosii ide only deal with the data on board, right?
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13812)</div>
[/b]
--- Quote End ---
Yes, you are right. But I hope I can just use JTAG and NiosII IDE to implement it. Since I can see the data in Nios Terminal Window on my screen(that is to say, the data must have been stored somewhere in the PC&#39;s memory), there must be some way to save the data as a file on my PC, right?
TO_BE_DONE
--- Quote Start ---
--- quote end ---
--- Quote End ---
Host Filing system is most appropriate for this job.
You should move to nios2 uClinux . And send back the data to PC via network.
Follow this link to setup uClinux,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
