12745 Discussions
How to use the CF in EP2C35(DEV kit)
Dear Hippo
Thank you for your help ,now I have run the linux in my board . Now I want to use the CF card in my board. can you tell me how to do it .
My board is the NIOSII EP2C35( altera DEV KIT ) .
Hi Alex,
You need to download the CF examples,
http://forum.niosforum.com/downloads/cflash/cf5_0.zip (http://forum.niosforum.com/downloads/cflash/cf5_0.zip
Use the 2C35's sof and ptf in the examples design.
In kernel config, select drivers->ata->altera CF
Dear HIppo
Now I have select drivers->ata->altera CF in kernel config, so I get The
Next Information when the system boot.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
smc_probe: 85000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x81000300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:
ed:0f:61:8e
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=1
hda: Hitachi XXM2.3.0, CFA DISK drive
ide0 at 0x81011000-0x81011007,0x81011038 on irq 7
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
NET: Registered protocol family 1
Freeing unused kernel memory: 2036k freed (0x4160000 - 0x435c000)
init started:  BusyBox v1.1.1-pre0 (2006.03.06-16:49+0000) multi-call binary
BusyBox v1.1.1-pre0 (2006.03.06-16:49+0000) Built-in shell (msh)
Enter &#39;help&#39; for a list of built-in commands.
# [/b]
--- Quote End ---
the kerner have check the CF card .
--- Quote Start ---
CF: ctl=1
ide0 at 0x81011000-0x81011007,0x81011038 on irq 7[/b]
--- Quote End ---
Now I shoud mount it
but i don&#39;t know which node is the CF card.
first i have select the VFAT in the kernel config
--- Quote Start ---
# cat /proc/filesystems
nodev sysfs
nodev rootfs
nodev bdev
nodev proc
nodev sockfs
nodev pipefs
nodev futexfs
nodev tmpfs
nodev ramfs
        vfat
nodev autofs[/b]
--- Quote End ---
but i find i got the next error
--- Quote Start ---
# mount -t vfat /dev/hda /mnt
mount: Mounting /dev/hda on /mnt failed: No such device or address# [/b]
--- Quote End ---
pls help me ! thanks!
Did you format the CF card on XP?
Try on nios2 linux, "fdisk /dev/hda".
Do you have this in kernel config?
<*> Include IDE/ATA-2 DISK support (NEW)
Thanks hippo , now I have find i miss the
now I config it i find the next information
--- Quote Start ---
hda: max request size: 128KiB
hda: 31488 sectors (16 MB) w/1KiB Cache, CHS=246/4/32
hda: hda1[/b]
--- Quote End ---
now I can find the hda1.
beacuse the size of my CF card is small ,16M byte, I have format it in my pc .
the fs format is FAT12 .
when i mount the disk , i got the next inforamtion
--- Quote Start ---
mount -t vfat  /dev/hda1 /mnt
hda: hda1
FAT: codepage cp437 not found
mount: Mounting /dev/hda1 on /mnt failed: Invalid argument[/b]
--- Quote End ---
now i have resolve the problem
beacuse I have select the language support
I select the native language support in menuconfig
Hi ALL
Now , I have mount the CF card into the linux . but i find when i create a file in the CF card , when i power off ,and then reboot the system and mount the CF card .but i can&#39;t the file . i want to know , does the fat system of linux have some problem???
Check your mounts with "cat /etc/mtab", or "df" .
You have to do "umount /mnt" or "shutdown" before power off.
You can also use "sync" to flush disk cache after write files.
Hippo thank you very much . i have write and read a file in CF card.
the case is over??
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
I summary it
if you want to use the CF card in nios2.
1. You need to download the CF examples,
Use the 2C35&#39;s sof and ptf in the examples design.
2. Mount it
3. when you write a file in card of cf ,you should make sure to be saved.
so you to do "umount /mnt
Beacuse I have only 2 month to learn the linux . hippo give me more help . thank you very much .
