How to wire to signal tap?
Contributeur émérite II
2 624 Visites
(* keep = 1 *) wire rx_bar_hit/* synthesis keep */; assign rx_bar_hit = (rx_desc | rx_desc) ? 1'b1 : 1'b0; But I can't add this signal to Siganl Tap.
If I add this signal manualy (just type this name in signal tap):
Critical Warning: Can't connect pre-synthesis signal "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|artem_dma:artem_dma0|rx_bar_hit" to port "trigger_in" on SignalTap II instance "auto_signaltap_0" because the signal does not exist in the pre-synthesis netlis
0 Compliments
10 Réponses
1 573 Visites
--- Quote Start ---
--- Quote End ---
which setting did you use in the node finder ? Post-Fitting ?? Which Quartus version do you use ?
Kind regards
GPK
0 Compliments
1 573 Visites
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
Hello. I'm try all settings. No one can find rx_bar_hit. Q9.1 Linux 64bit.
0 Compliments
1 573 Visites
--- Quote Start ---
--- Quote End ---
strange, at least "All Names" should show the signal. Did you try wildcards like rx_bar* ?
Kind regards
GPK
0 Compliments
1 573 Visites
--- Quote Start ---
GPK
--- Quote End ---
Yes,
"Design Entry (all names)" don't show this signal. Even if I make (* noprune *) (* keep = 1 *) wire rx_bar_hit;
0 Compliments
1 573 Visites
--- Quote Start ---
Yes,
--- Quote End ---
did you get a warning like this : "object "rx_bar_hit" assigned a value but never read" ?
That means the signal "rx_bar_hit" is not used in your design and it looks like that it
is removed regardless of your "keep" assignment. I assume "keep" will only work in order
to prevent the signal to be removed by the synthesis engine.
BTW: "noprune" works only for reg ! in case they have no fan out.
Kind regards
GPK
0 Compliments
1 573 Visites
--- Quote Start ---
--- Quote End ---
Yes. I'm not use this wire yet. But I'm expected that wire will be used by Signal Tap.
--- Quote Start ---
--- Quote End ---
So, there are no way to make wire only for Signal Tap?
0 Compliments
1 573 Visites
--- Quote Start ---
--- Quote End ---
it looks like that, but you can try to capture the wire signal with a register and preserve the register with "noprune".
Kind regards
GPK
0 Compliments
1 573 Visites
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
I looked into the Quartus Help and found this restriction for "keep":
"You cannot use this synthesis attribute for nodes that have no fan-out."
0 Compliments
1 573 Visites
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
--- Quote Start ---
(* noprune *)reg rx_bar_hit_reg;
always @ (posedge clk_in) begin
rx_bar_hit_reg <= rx_bar_hit;
end
--- Quote End ---
Worked.
Thanks for all.
0 Compliments
1 573 Visites
you can also route those signals to outside pins, to leds for instance.
a colegue of mine suggested me to XOR all signals that i want to debug and route result to LEDs.
0 Compliments
Répondre
