12746 Discussions
How to write a makefile to compile C project ?
Hi all !
I'm using Cyclone 1c12 eval, Microtronix uCLinux 1.4, NIOS II IDE 5.0
I have a C project (which will run on uCLinux) as following:
header files:
libA.h
libB.h
c files:
a.c
b.c
c.c
main.c // <-- this file contains function main()
How can I write a makefile ( makefile & rule.mak ) for above project or edit the Microtronix template ?
Thank you
OneNet
Hi OneNet,
First read the Linux Reference Guide section, "Creating a Makefile" ... basically, you just need
to include the Rules.mak and pretty much do what you would always do.
E.g.:TARGET  = foo.exe CSRC    =  foo.c bar.c OBJS    = $(CSRC:.c=.o)                  # All object files LDFLAGS += # ################################################################# .PHONY: default install clean realclean distclean depend default: deps $(TARGET) install:     cp -pf $(TARGET) $(BIN_INSTALL) clean:     rm -rf $(OBJS) core distclean: clean     rm -f deps     rm -rf $(TARGET) depend: deps sinclude deps include Rules.mak
--Scott
Sorry, I must have fat fingered the following (missing from above):
deps: Makefile $(CSRC)     $(CC) -M $(CFLAGS) $(CSRC) > deps
--Scott
Dear scott !
Your solution is very clear !
thank you so much
OneNet
