12748 Discussions
I cannot launch Nios II Software Build Tool for Eclipse (Quartus Prime 18.1).
YHiro4
To​ launch Eclipse, a dialog pop-up. "An error has occurred. See the log file"
The Contents of log file is
!SESSION 2018-11-01 09:50:57.513 -----------------------------------------------
eclipse.buildId=4.5.2.M20160212-1500
java.version=1.8.0_05
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=ja_JP
Framework arguments: -product org.eclipse.epp.package.cpp.product -pluginCustomization C:/intelfpga_lite/18.1/nios2eds/bin/eclipse_nios2/plugin_customization.ini
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.cpp.product -pluginCustomization C:/intelfpga_lite/18.1/nios2eds/bin/eclipse_nios2/plugin_customization.ini
!ENTRY org.eclipse.osgi 4 0 2018-11-01 09:51:00.009
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.cdt.codan.core.application, org.eclipse.cdt.core.GeneratePDOM, org.eclipse.cdt.managedbuilder.core.headlessbuild, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool.
 at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
 at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
 at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
 at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
 at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
 at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
 at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
 at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
 at java.lang.reflect.Method.invoke(Unknown Source)
 at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
 at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
 at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
 at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
what to do to launch Eclipse?
AnandRaj_S_Intel
Run as administrator.
or reinstall quartus and check.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
YHiro4
Hell Anand I try to run as administrator, and uninstall/reinstall. But,erro is still occurred. Is there what to do to solve this problem?
AnandRaj_S_Intel
I'm using Quartus​ lite 18.1 in windows 10.
We can successfully launch eclipse without any error.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)EclipselaunchQ18.1Lite.JPG
Abe
Valued Contributor II
Install the latest Java Run time and then check if you can launch Eclipse. The Eclipse tools require the latest Java v8 and above to run.
YHiro4
Hi, Abe
My environment is
 Windows7 Professional SP1 64bit
 ​Nios II EDS 18.1.0.625
 Java Version 8 Udate191.
Java is latest version ,but don't run eclipse.
I tried uninstall Quartus Prime and Java, and Install only Quartus Prime.
So,Eclipse Normaly Run.
