dear sir
i have problem with the following : after we seting the build the kernel config seting the NIOSII cyclone board statement shown below: [sopc]=$nios2-flash-programmer --base =0x0000000 vmlinux.flash out put : using cable "ByteblasterII [lpt1]",device 1,instance 0x00 resetting and pausing target processor:OK checksum took 1.1s Erased 1792kb in 20.3s(88.2 kb/s) programmed 1875kb in 76.4s(24.5kb/s) leaving target processor paused the task exit [sopc]=$ please help me i hope to get the replay as soon as possible ?Link Copied
Did you remember to start a nios2-terminal session?
Try this (within NiosII IDE shell)...nios2-download --go vmlinux; nios2-terminal
--- Quote Start --- originally posted by hootsmon@Mar 21 2006, 05:11 AM did you remember to start a nios2-terminal session?
try this (within niosii ide shell)...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13616)</div> --- Quote End --- hi i have recived your replay but i have doubt i have 1.NiosII evaluation board 2.USB cable 3.Altera design software suit 4.NiosII evalution kit user guide 5.Nios II embedded processor Evalution edition 6.Quartus II web edition software I dont have the following 1.Ethernet cable 2.Ethernet cable crossover connector. can help me without the Ethernet we can work it or not ?
