I2C Build errors
I am using Quartus II 4.2, Nios II development kit 1.1 installation.
I was able to build the kernel and download successfully for
altera stratix development board.
Howerver when trying to build kernel with i2c support,
I am getting errors pasted below:
I have also included the .config file for your reference.
Looks like i have to initialise the na_i2c_* variables for my board.
Looks like the same needs to be done for na_uart_* variables.
Can you tell me whether there is a standard way of doing it, any header files,
Or how to do it
Any help will be appreciated
Errors:
drivers/i2c/.i2c-core.o.d: done.
CC drivers/i2c/algos/i2c-algo-oc.o
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/algos/i2c-algo-oc.c: In function `i2c_oc_add_bus':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/algos/i2c-algo-oc.c:385: warning: unused variable `oc_adap'
drivers/i2c/algos/.i2c-algo-oc.o.d: done.
LD drivers/i2c/algos/built-in.o
CC drivers/i2c/busses/i2c-oc.o
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:164: error: `na_i2c_0' undeclared here (not in a function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:164: error: initializer element is not constant
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:164: error: (near initialization for `oc_hw_0.base')
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:165: error: `na_i2c_0_irq' undeclared here (not in a function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:165: error: initializer element is not constant
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:165: error: (near initialization for `oc_hw_0.irq')
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:170: error: `na_i2c_1' undeclared here (not in a function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:170: error: initializer element is not constant
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:170: error: (near initialization for `oc_hw_1.base')
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:171: error: `na_i2c_1_irq' undeclared here (not in a function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:171: error: initializer element is not constant
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:171: error: (near initialization for `oc_hw_1.irq')
make[4]: *** [drivers/i2c/busses/i2c-oc.o] Error 1
make[3]: *** [drivers/i2c/busses] Error 2
make[2]: *** [drivers/i2c] Error 2
make[1]: *** [drivers] Error 2
make: *** [_all] Error 2
make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
They are defined in SOPC builder, and exported to Linux through a dynamic generated header file called nios2_system.h
