So I just found this crazy feature that you might already know about in eclipse called "Link with Editor", which can be set from the "Navigator View". Check this button and if you have more then one project open at once then whichever file in the editor you select will change eclipses project focus in the Projects View to be that ptoject... Kinda Cool.
