IDE compiler features?
Hi!
I have a question about IDE compiler features.
I've made a board with CFI flash and Ethernet controller
on the same tri-state bridge. CFI flash (data 8 bits) has dynamic
alignment (A[0] = A[0]) and Ethernet controller (data 8 bits) has
native alignment (A[0] = A[2]). But when I was tracing my board I've
made error and put A[0] of Ethernet controller to A[0] of tri-state
bridge.
I've tried to describe ethernter controller as memory device (dynamic
alignment) and created next structure for it in C:
....................# pragma pack(1)
typedef struct _cs8900
unsigned char DATA0L;
unsigned char DATA0H;
unsigned char DATA1L;
unsigned char DATA1H;
unsigned char TxCMDL;
unsigned char TxCMDH;
unsigned char TxLENGTHL;
unsigned char TxLENGTHH;
unsigned char ISQL;
unsigned char ISQH;
unsigned char PACKETPAGE_POINTERL;
unsigned char PACKETPAGE_POINTERH;
unsigned char PACKETPAGE_DATA0L;
unsigned char PACKETPAGE_DATA0H;
unsigned char PACKETPAGE_DATA1L;
unsigned char PACKETPAGE_DATA1H;
} cs8900;# pragma pack()
volatile cs8900 *p =(cs8900*) CS8900_BASE;
but when I'm reading p->DATA0L or p->DATA0H there is always zero.
When I'm writing there is OK. And in generaly it works.
Maybe someone has any idea?
Thx.
