IDE window preferences
Is there a way to preset window preferences such as always using hex format as default for registers,variables?
From the menu select
Window->Preferences
Expand the C/C++ tab select the Debug tab there are now three drop down boxes in the right of the window, this should serve your purpose
Thank you, thank you, thank you. This has been driving me crazy since I started using Eclipse.
Thanks, missed that one.
How about the ability to show mixed assembly/C in debug?
Sorry that's not possible with this version of Eclipse
Also, is there a way to stop it from removing any added variables/expressions when you rebuild?
Not in Nios 1.1 and earlier. Try out the recently released version of Nios (5.0) - the IDE features mixed/c assembly debugging and persistent global variables and expressions.
