IRQ mapping in SOPC builder
I fixed up the device address (na_usb - to the address assigned to ISP1362 in SOPC builder) and irq (na_usb_irq - IRQ 4 when viewed in SOPC builder) and corrected the chip id so linux recognizes the usb port, but i get the following error about the IRQ after i plug in a USB flash drive. I checked the DE2_NET design I'm using for this experiment in SOPC builder and the IRQ for ISP1362 is 4, or should i instead be using the IRQ for the DMA?
thanks in advance!
io scheduler deadline registered
116x: driver isp116x-hcd, 08 Apr 2005
116x: ISP116x Host Controller, irq 4
isp116x-hcd isp116x-hcd: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
scheduling while atomic: swapper/0x00000002/1
Stack from 00187d40:<0>
<0> 00000002<0> 000d53cc<0> 00000001<0> ffffe000<0> 00002900<0> 001922ec<
0> 00189b20<0> 00356c00<0>
<0> 40408180<0> 00000002<0> 000e5504<0> ffff8c59<0> 00000006<0> 000d696c<
0> 00150020<0> 00150020<0>
<0> ffff8c59<0> 4b87ad6e<0> 000170f0<0> 00182d60<0> 0014fd50<0> 00000002<
0> ffffe000<0> 80000080<0>
<0> 000175bc<0> 001921c0<0> 00192280<0> 000be790<0> 001921c0<0> 00192280<
0> 000bf130<0> 000df488<0>
<0> 00000000<0> 00189a20<0> 0000000d<0> 000001f4<0> 00356c04<0> 00357d9c<
0> 000600fc<0> 00179200<0>
<0> 0035ada4<0> 00000000<0> 00192294<0> 00356a00<0> 00000001<0> fffffffa<
0> ffffffed<0> 000ecc94<0>
Call Trace:<0>
<0> [<000bcf18>]<0> [<000a1e04>]<0> [<000a1eb8>]<0> [<00000001>]<0>
<0> [<00000000>]<0> [<00000000>]<0> [<000a20a8>]<0> [<00000000>]<0>
<0> [<000a0e68>]<0> [<00000000>]<0> [<00000000>]<0> [<000c5c68>]<0>
<0> [<00000001>]<0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0>
<0> [<000001f4>]<0> [<00000001>]<0> [<00000000>]<0> [<000bf95c>]<0>
<0> [<00000012>]<0> [<00000012>]<0> [<00000012>]<0> [<000c2034>]<0>
<0> [<00000001>]<0> [<000a1e04>]<0> [<000a1f74>]<0> [<00000000>]<0>
<0> [<000a22c8>]<0> [<00000001>]<0> [<000a2830>]<0> [<00000000>]<0>
<0> [<00000000>]<0> [<00000264>]<0> [<00001d64>]<0> [<00006910>]<0>
<0> [<00006968>]<0> [<0000088c>]<0> [<00000000>]<0> [<00000000>]<0>
<0> [<00000000>]<0> [<000052a8>]<0> [<00000000>]<0> [<00000001>]<0>
<0> [<00000b00>]<0> [<00000b00>]<0> [<0000019c>]<0> [<00000000>]<0>
<0> [<00000120>]<0> [<00000001>]<0> [<00000001>]<0> [<00001d54>]<0>
drivers/usb/class/bluetty.c: USB Bluetooth support registered
usbcore: registered new driver bluetty
drivers/usb/class/bluetty.c: USB Bluetooth tty driver v0.13
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
Freeing unused kernel memory: 348k freed (0xf2000 - 0x148000)
init started: BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary
BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) Built-in shell (msh)
Enter &#39;help&#39; for a list of built-in commands.
# usb 1-2: new full speed USB device using isp116x-hcd and address 2
isp116x-hcd isp116x-hcd: Unlink after no-IRQ? Controller is probably using the
wrong IRQ.
Why do you want bluetty?
If you want bluetooth support, maybe you should select from top level menuconfig,
Networking --> [*] Bluetooth subsystem support ---> Bluetooth device drivers ---> [*] HCI USB driver
The isp116x driver does not use DMA. It looks like the hcd driver crashed after detecting port
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
scheduling while atomic: swapper/0x00000002/1[/b]
--- Quote End ---
You should enable DEBUG in your driver, or add some printk() to find out.
You should try out the 2.6.15.6 kernel in the update of the buildroot guide.
hmm, I don&#39;t see any DEBUG option in the makefile, how do i enable the debug option?
thanks!
The problem should be in arch/nios2nommu/kernel/usb.c .
But you have to enable the DEBUG in drivers/usb/host/isp116x-hcd.c to find out.
you should use kernel 2.6.16 .
thanks, i&#39;ve traced down the problem using the trace and printks to an msleep call in drivers/usb/core/hub.c in the 2.6.x kernel
Just tried compiling 2.6.16 kernel but it seems some of the data structures aren&#39;t complete or don&#39;t match up.
the isp116x_platform_data data structure seems to be missing some things that usb.c assumes are there and is trying to initialize.
Yes, there may be new data structures and api in new kernel, which makes old driver failed.
so in that case should i be updating the 2.6.16 kernel with the more complete code from 2.6.x? some of the code in 2.6.16 have data structures which have some data members stripped out for some reason
--- Quote Start ---
some of the code in 2.6.16 have data structures which have some data members stripped out for some reason[/b]
--- Quote End ---
You should update arch/nios2nommu/usb.c data structure for newer kernel.
I will try to borrow a DEII board, and I will check it then.
After some searching on web, I found this about isp1362 linux stack,
http://www.semiconductors.philips.com/acro...s/um10012_2.pdf (http://www.semiconductors.philips.com/acrobat/usermanuals/um10012_2.pdf
There is isp1362_linux_sw_stack.tar.gz
http://www.semiconductors.philips.com/prod...ducts/download/ (http://www.semiconductors.philips.com/products/connectivity/usb/products/download/
Email authorization
Software marked "email authorization required" needs prior approval from Philips Marketing for download.
--- Quote Start ---
originally posted by hippo@Mar 29 2006, 09:17 PM
after some searching on web, i found this about isp1362 linux stack,
there is isp1362_linux_sw_stack.tar.gz
email authorization
software marked "email authorization required" needs prior approval from philips marketing for download.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13910)
--- quote end ---
--- Quote End ---
Thanks hippo!
while looking for guides about porting over drivers, i found this for the 2.6.x distribution
http://blackfin.uclinux.org/plugins/scmcvs...root=uclinux533 (http://blackfin.uclinux.org/plugins/scmcvs/cvsweb.php/uclinux-dist/linux-2.6.x/drivers/usb/host/?cvsroot=uclinux533
not sure if any changes need to be made since the hardware is different from blackfin? (in the header files)
i&#39;ve tried plugging in a usb flash drive but nothing happens after trying:
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6528k/8192k RAM, 0k/0k ROM (1090k kernel code, 460k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Bluetooth: Core ver 2.7
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au
devfs: boot_options: 0x1
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x81004000 (irq = 0) is a jtag_uart
io scheduler noop registered
Freeing unused kernel memory: 352k freed (0x120000 - 0x177000)
# cd proc# more mounts
rootfs / rootfs rw 0 0
/proc /proc proc rw,nodiratime 0 0
sysfs /sys sysfs rw 0 0
none /proc/bus/usb usbfs rw 0 0# mount -t vfat /dev/hda1 /mnt
mount: Mounting /dev/hda1 on /mnt failed: No such device or address# mount -t vfat /dev/hda /mnt
mount: Mounting /dev/hda on /mnt failed: No such device or address
am i using the wrong mount command?
--- Quote Start ---
1. in root fs, you need some scsi dev nodes, eg sda, sda1... to use mass storage dev
you need usbfs, too. I have setup them in the post of buildroot guide, so they are ready.
2. in kernel menuconfig,
turn on file system support, eg, vfat and native lang codepage 437
turn on scsi device, scsi disk
turn on host-side usb, usb dev fs, your hcd, usb device eg mass storage.[/b]
--- Quote End ---
for 1. do i need to do anything else for sda and sda1? - usbfs seems to be registered
for 2. i&#39;ve enabled all of those options.
sorry about the huge post but thx in advance!
Shindou,
Good found, It looks like the piece of driver you need. you have to update your arch/nios2nommu/kerbel/usb.c to prepare for the probing of the 1362 hcd. You should enable the debug message, too. You have to "port" the driver to your nios2 board. (it is not plug-and-play...).
The 1362 hcd should detected first, then the root hub.
Then when a usb disk inserted it will detect the new usb mas storage device, and display the usb disk info.
--- Quote Start ---
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd.0: ISP1362 Host Controller
isp1362_hc_reset:
isp1362-hcd isp1362-hcd.0: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd.0: irq 28, io mem 0x0c000000
isp1362_hc_start:
isp1362-hcd isp1362-hcd.0: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd.0: ISTL:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd.0: INTL: 16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd.0: ATL : 32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd.0: USED/FREE: 3968    128
ISP1362 Host Controller, irq 28
usbcore: registered new driver cdc_acm
drivers/usb/class/cdc-acm.c: v0.23:USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
pegasus: v0.6.12 (2005/01/13), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new driver pegasus       [/b]
--- Quote End ---
This is what I found from the net, about the boot log of isp1362 on arm.
I am trying to add isp1362-hcd to nios2 kernel, and will let you know when I compile through.
I can not borrow a DEII board, so it is up to you to test them.
Shindou,
Please find the isp1362.zip attached in post#1 of buildroot guide.
cd ~/download unzip isp1362.zip cd ~/linux-2.6.16.1 patch -p0 <~/download/isp1362-nios2-01.diff
rebuild the kernel from hwselect,menuconfig .
thanks hippo, just tried it out with the nios_0.ptf
uClinux/Nios II
Built 1 zonelists
Memory available: 6508k/8192k RAM, 0k/0k ROM (1136k kernel code, 452k data)
Bluetooth: Core ver 2.8
io scheduler deadline registered (default)
ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
usbmon: debugfs is not available
Bluetooth: HCI USB driver ver 2.9
usbcore: registered new driver hci_usb
Freeing unused kernel memory: 352k freed (0x12a000 - 0x181000)
didn&#39;t see anything pop up when i plugged in a usb flash drive though. i&#39;ll update the thread as i debug if i find anything or get it to work.
it didn&#39;t initialize the isp1362-hcd,
Did you select isp1362 hcd in kernel menuconfig?
Try add some printk and debug to the code, arch/nios2nommu/kernel/usb.c and drivers/usb/host/isp1362-hcd.c .
It seems like it&#39;s getting to the usb_hcd_init() call in arch/nios2nommu/kernel/usb.c where platform_device_register(&isp1362_hcd) is called but it seems the init code in drivers/usb/host/isp1362-hcd.c (ie. isp1362_init() is never called)
last edit:
Yep, ISP1362 HCD is selected in the menuconfig - hmm, interesting point tho, there&#39;s no object file after the make (ISP1362-hcd.o) in the drivers/usb/host directory. It&#39;s strange tho, the code in an adjacent directory drivers/usb/core had object files. Probably explains the problem above why that code never got called. Gonna see if i can figure out why this makefile isn&#39;t compiling isp1362-hcd.c.
try make clean, and rebuild kernel from hwselect again.
I did try compile with DE2 ptf . there should be the isp1362-hcd.o .
Found the problem, the Makefile in the drivers/usb didn&#39;t point to the drivers/usb/host directory for ISP1362 selection in menuconfig.
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362_hc_reset:
Clock not ready after 20ms
isp1362-hcd isp1362-hcd: can&#39;t reset
init error, -19
Freeing unused kernel memory: 352k freed (0x13c000 - 0x193000)
can start debugging the reset problem now
--- Quote Start ---
originally posted by shindou@Apr 6 2006, 09:18 AM
found the problem, the makefile in the drivers/usb didn&#39;t point to the drivers/usb/host directory for isp1362 selection in menuconfig.
serial: jtag uart driver $revision: 1.4 $
ttyj0 at mmio 0x81004000 (irq = 1) is a jtag_uart
isp1362-hcd isp1362-hcd: isp1362 host controller
isp1362_hc_reset:
clock not ready after 20ms
init error, -19
initializing usb mass storage driver...
usb mass storage support registered.
bluetooth: hci usb driver ver 2.9
freeing unused kernel memory: 352k freed (0x13c000 - 0x193000)
init started:  busybox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14079)
--- quote end ---
--- Quote End ---
yes, drivers/usb/Makefile line17 should be changed to ISP1362 .
let me know if you have progress in the debug http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
