Including external libraries
I would very really like to include the public Crypto++ library into my NIOS system. Is this possible? Any hints?
I need to deal with BIG integers (2048bit) for RSA and I'm at a loss
Thanks!
Pretty generic question, however, you could try downloading the software onto your workstation and seeing if it will compile natively under Cygwin (or Linux). Typically these packages have a "configure" script which will auto-setup the build process for you, after which you can run "make". If this works, then you can drag the sources into the Nios II IDE, after setting up a managed software library project.
I've done this in the past, seemed to work just fine with an MPEG library I was playing around with.
Sorry to be soooo vague with the answer. Either PM me or post more details on what you're doing.
Cheers,
Chris
--- Quote Start ---
originally posted by mike_r@Jun 22 2006, 09:30 AM
i would very really like to include the public crypto++ library into my nios system. is this possible? any hints?
i need to deal with big integers (2048bit) for rsa and i'm at a loss
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16338)
--- quote end ---
--- Quote End ---
