- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Anyone else having problems installing eCos 2.0? The installer insists that I do not have Nios2 1.01 installed. I installed the original 1.0 from CD and the 1.01 from SP1 (downloaded from Altera).
Any ideas?Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The installer looks in the install directory inside a file version.ptf for the version of your kit. I suspect your problem is that you're not installing to the directory where your kit is installed
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Ok, I should have included my ptf (from c:\altera\kits\nios2) information in my first post:
number = "1.01"; major = "1"; minor = "0"; level = "1"; build = "393b"; type = "patch"; host = "sc-build"; user = "sc-regtest"; date = "2004.09.07"; time = "17.13.10"; The eCos installer wants to install to .\components\ecos. I modified this to c:\altera\kits\nios2\components\ecos (and c:\altera\kits\nios2) and the installer gives me "Error You have either not got the NiosII 1.01 kit installed or the environment variable SOPC_KIT_NIOS2 points to a different version of the Nios II kit. Please install version 1.01 to continue" My environment variable is set to: SOPC_KIT_NIOS2=c:\altera\kits\nios2 I will keep poking around.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Ok, if I try a number of times and add a backslash to c:\altera\kits\nios2\ I can get the setup to continue. I will if I can create a build a project.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Ok, I am awake now (after noticing missing words in my previous post). Not quite sure what happened but I uninstalled everything including Quartus. During the reinstall, everything installed without problems.
Thanks all!
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
