12747 Discussions
Instructions do not work with custom floatt
Hi Everybody!!!
I created a custom instruction and it is not working for floating point. It worked only with integer value. I've used the macro that was defined in the Altera Manual:
# define ALT_CI_TESTE_INST_N 0x00000000
# define ALT_CI_TESTE_INST (A) __builtin_custom_fnf(ALT_CI_TESTE_INST_N, (A))
By the manual should be working.
Excerpt from my test code
# include <stdio.h>
# include "system.HA"
int main ()
float x = ALT_CI_TESTE_INST (0.0);
printf ( "Value:% f", x);
return 0;
The following appears on the console:
Value:
If anyone can help me, please respond. I am Brazilian and I do not know English very well, then no doubt, explain again.
Thank you!!!!
Try this instead:
float x = ALT_CI_TESTE_INST(0.0f);
The 'f' tells the compiler to use a single precision value instead of double precision (default). There is also a flag you can pass to the compiler to tell it to treat all floating point constants as type 'float' instead of 'double' but I forget what to use (I don't recommend it either since you might accidentally break some code that needed to use double precision constants).
