12745 Discussions
Internal port timing detail in simulation
Could be a fundamental question.
I was trying to study accurate timing of internal port. (not stand alone register)
I used to do this by adding OUTPINs in design, since doing this will introduce path delay into timing simulation, which is not desirable.
In Node Finder of wave editor, options of filter:
registers: pre-synthesis
registers: post-fitting
design entry (all names)
post compilation
might be right for use, but I failed in getting any effective output from my design.
Generally my top level design is in schematic.
Need timing of ports, should I register them? or there are other options?
Please help,
Thx
