12747 Discussões
Interrupt handler API changed in 2.6.19
Colaborador honorário II
1.484 Visualizações
If you are developing kernel drivers,
please note, the interrupt handler API changed in 2.6.19 .
Read this,
http://lwn.net/articles/202449/ (http://lwn.net/articles/202449/
I am trying uClinux-dist-test-20070108. We will need to come up with the new interrupt API.
10 Respostas
755 Visualizações
Have anyone tried to get 2.6.19.x to work on Nios2 yet ?
I've done a port which is mostly OK, but I have experienced a couple of issues not present in 2.6.18:
* /proc/<pid>/cmdline is empty for all processes. This could possibly be releated to the new kernel_execve call (used to start init).
* Top (from busybox) is using up to 100% CPU. Probably some /proc problems (top monitors /proc/stat).
755 Visualizações
I am working on uClinux-dist-test-20070108, which uses 2.6.19 . I haven&#39;t got through yet.
Could you attach your patches on the wiki,
http://nioswiki.jot.com/wikihome/operating...s/kernelpatches (http://nioswiki.jot.com/wikihome/operatingsystems/kernelpatches)
755 Visualizações
Sure. I&#39;ll see if I can generate a diff with my changes from 2.6.18 to 2.6.19.
755 Visualizações
The patch is uploaded to:
http://nioswiki.jot.com/wikihome/operating...9-nios2.diff.gz (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/kernelpatches/linux-2.6.18_to_2.6.19-nios2.diff.gz
It&#39;s generated against my own sources, so I can not guarantee that it will apply cleanly against 2.6.19 + the nios2-patch (2.6.18) on the wiki, or that all required changes are in there. But at least you&#39;ll get an idea about what changes that have to be done.
755 Visualizações
Thank you very much.
It would be very helpful. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hippo
755 Visualizações
Hi atlenisse,
I&#39;ve adapted your patches, and got the same issues of /proc//cmdline, environ...
But /proc//status, stat are correct.
I wonder if there are problems on task->mm. Do you have any found?
Hippo
755 Visualizações
Hello Hippo,
I&#39;m sorry but I haven&#39;t had the time to look into this since I initially did the port (before X-mas). I chickened out and rolled back to 2.6.18...
One thing I noticed is that the proc-behaviour of processes started from init/sh is exactly as for kernel-processes (started by kthread_run, e.x kjournald), so I suspected that this issue could be related to the new kernel_execve call (starting with v2.6.19 init is started with kernel_execve() instead of using the execve syscall).
But if it is so, this issue would (possibly) also apply to other architectures, and I have not seen any bug reports anywhere.
755 Visualizações
I traced proc fs.
It seems to be problem of access_process_vm() in linux-2.6.x/mm/nommu.c .
several nommu stuff updated in 2.6.19 .
755 Visualizações
755 Visualizações
Nice! This fixed the cmdline-issue, but top is still acting weird. I&#39;ll post a question about this on the uClinux list.
Responder
