The kernel and filesystem compile ok, but when I try to start the linux with nios-terminal I get this, over and over again:
Linux version 2.6.11-uc0 (JRo@JMILARO) (gcc version 3.4.1 (Altera Nios II 5.0 b7
3))# 4 Wed Jun 14 11:02:30 2006
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 14168k/16384k RAM, 0k/0k ROM (1674k kernel code, 348k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x821208d0 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 50000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:
ed:0b:57:93
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=8
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00600000-0x00700000 : "User configuration"
0x00700000-0x00800000 : "safe configuration"
116x: driver isp116x-hcd, 08 Apr 2005
116x: ISP116x Host Controller, irq 11
isp116x-hcd isp116x-hcd: new USB bus registered, assigned bus number 1
116x: Invalid chip ID 0123
isp116x-hcd isp116x-hcd: USB bus 1 deregistered
116x: init error, -19
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
USB dc ISP1161 is not present
After that last line, it jumps back to the beginning. Any ideas? Could the chip be busted? The id seems like a default id. edit: Yep, the Cyclone board was busted, not the Microtronix kit. I switched to Stratix II and it recognized the id correctly, as you might guess the id was 6123 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif . Oh well...
