I want to use Simplify for compilation process of my NIos2 system
Can someone explain how to do it ? In my project i have one part in AHDL and all other files in Verilog Top level is ALEXS_BOARD_BLOCK.dbf (is block diagramm) I was trying to set extarnal compilation tool in quatrus My steps is : 1. Open workable design 2. Open project settings 3. Open "EDA Tool Settings"->"Design Entry & Synthesis" 4. Select Tool name -> "Synplify Pro" 5. Set Format - 'Verilog HDL" 6. Set checkbox - "Run this tool automaticaly.... " 7. Select Library Mapping File "C:/Program Files/synplicity/Synplify_73/lib/synplcty.lmf" (it present) 8. Click OK 9. run synthesis And have following srr file from simplify ________________________________________________ $ Start of Compile# Mon May 23 09:07:52 2005 Synplicity Verilog Compiler, version Compilers 7.3, Build 073R, built May 30 2003 Copyright © 1994-2002, Synplicity Inc. All Rights Reserved @I::"D:\ALTERA_PRJ\CYCLC6\alexbrd_ver\mmc\altsyncram0.v" @I::"D:\ALTERA_PRJ\CYCLC6\alexbrd_ver\mmc\avalon.v" @I::"D:\ALTERA_PRJ\CYCLC6\alexbrd_ver\mmc\mux2.v" @I::"D:\ALTERA_PRJ\CYCLC6\alexbrd_ver\cf_PLAY\scfifo0.v" @I::"D:\ALTERA_PRJ\CYCLC6\alexbrd_ver\cf_PLAY\sound.v" @I::"D:\ALTERA_PRJ\CYCLC6\alexbrd_ver\DQM_ANALYZER.v" Verilog syntax check successful! @E|No component with name ALEXS_BOARD_BLOCK to synthesize @END Process took 0h:0m:0s realtime, 0h:0m:0s cputime ________________________________________________ How to fix this ?Link Copied
