12746 Discussions
Is .text data not located in flash memory?
HELP!
When I down my program to the My board---ep2c35, I set .text and .rodata into flash memory in System Library Page.Built project.............OK! RUN AS HARDWARE...................Verify failed! SO I set .text and .rodata into SSRAM,all is fine.
why?why I can not place .text data into flash?Anyone have some advice?Thanks!
You should be able to place .rodata and .text in flash, but you've got to program the flash after doing this.
Cheers,
- slacker
