12748 Discussions
Is there a disassembler for Nios II ELF files?
I'd like to be able to examine the ELF file that the compiler generates so I can see exactly which instructions are being used. I have the Nios II Processor reference document which shows the opcodes, but I haven't seen anything about a dissassembler.
Also where can I read about what exactly goes in each section of the ELF file? For instance, what goes in the .exceptions section? From looking at the program headers it seems like this should be executable code but it doesn't look like executable code in a hex editor.
Hi bkucera,
Use objdump with the -D option.
Take a look at your linker command file, use objdump ... and you might want to
generate a map file as well.
--Scott
--- Quote Start ---
originally posted by smcnutt@Dec 13 2005, 05:14 PM
hi bkucera,
take a look at your linker command file, use objdump ... and you might want to
--- Quote End ---
Great, objdump is what I was looking for. Where is my linker command file, and how do I generate a map file? Thanks!
Look in your system library path. E.g. for a debug build:
xxx\Debug\system_description\generated.x
Pass the -Map option to the linker:
$ nios2-elf-ld [OTHER OPTIONS] -Map app.map
Use -Wl,-Map -Wl,app.map for gcc.
--Scott
There is another possibility:
If you are looking for a debugger which directly reads in the ELF file than we can provide a commercial product. This debugger shows besides the opcode and the corresponding disassembled mnemonics also the program flow and cycle count information (per instruction or accumulated over time), and many more features.
You can download this product from www.adveda.com, you can use it for two weeks (license is time limited).
Thanks all of you!
It's very kind of you!
I'm from china, and there are few people using NiosII, so I feel alone!:(
Now, I won&#39;t feel alone anymore, because I find my home!:) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
Thanks again!
