JPEG libraries
Hello All,
I am currently working on a project where I have to read image files (JPEG) from a USB and displaying them on the screen. I installed uClinux and I was wondering if you could give me an advice on what libraries to use for the JPEG decoding. Also, could we display the pics using an X window or not?
Bouyaka
Please check the wiki
http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operatingsystems/framebuffer
If you use the DE2 board, you can read the USB disk as mass storage device, and display the JPEG file with nxview on nanoX window.
--- Quote Start ---
originally posted by hippo@Mar 29 2007, 08:25 PM
please check the wiki
if you use the de2 board, you can read the usb disk as mass storage device, and display the jpeg file with nxview on nanox window.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22641)
--- quote end ---
--- Quote End ---
Thanks for the prompt answer!! Do you have any good links with information on nxview ?
Bouyaka.
--- Quote Start ---
originally posted by bouyaka+mar 30 2007, 04:50 pm--><div class='quotetop'>quote (bouyaka @ mar 30 2007, 04:50 pm)</div>
--- quote start ---
<!--quotebegin-hippo@Mar 29 2007, 08:25 PM
--- quote end ---
--- Quote End ---
Bouyaka.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22685)</div>
[/b]
--- Quote End ---
I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operatingsystems/framebuffer
but I ran into this error when trying to run make in the uClinux-dist/
arch/nios2nommu/drivers/altfb.c: In function `altfb_probe&#39;:
arch/nios2nommu/drivers/altfb.c:161: error: `na_vga_controller_0&#39;
undeclared (first use in this function)
arch/nios2nommu/drivers/altfb.c:161: error: (Each undeclared
identifier is reported only once
arch/nios2nommu/drivers/altfb.c:161: error: for each function it
appears in.)
make[2]: *** [arch/nios2nommu/drivers/altfb.o] Error 1
make[1]: *** [arch/nios2nommu/drivers] Error 2
--- Quote Start ---
originally posted by bouyaka@Mar 29 2007, 04:59 PM
hello all,
i am currently working on a project where i have to read image files (jpeg) from a usb and displaying them on the screen. i installed uclinux and i was wondering if you could give me an advice on what libraries to use for the jpeg decoding. also, could we display the pics using an x window or not?
thanks.
bouyaka
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22636)
--- quote end ---
--- Quote End ---
Hi, Bouyaka
I will use USB Camera to read image(JPEG) on DE2 board.
Can you tall me ,what kind usb camera is your used?
It&#39;s need porting usb driver?
Can you teach me?
thanks
NiosQ
--- Quote Start ---
originally posted by niosq+apr 2 2007, 03:07 am--><div class='quotetop'>quote (niosq @ apr 2 2007, 03:07 am)</div>
--- quote start ---
<!--quotebegin-bouyaka@Mar 29 2007, 04:59 PM
hello all,
thanks.
bouyaka
--- quote end ---
--- Quote End ---
Hi, Bouyaka
Can you teach me?
thanks
NiosQ
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22728)</div>
[/b]
--- Quote End ---
I am using a normal USB storage device (flash drive) where JPEG pictures will be stored.
nxview is a demo program of nanoX.
when you enable jpeg support in microwin/nanoX, the libjpeg will be selected.
I updated the wiki.
--- Quote Start ---
Hello All,
Bouyaka
--- Quote End ---
Hi,Bouyaka, are you succesfull display the JPEG picture using nxview to VGA monitor?? Currently I also work a project same with you, if u succesfull make it can share experience to me? Thanks very much for reply =)
