JTAG UART read interrupt
Hey all,
I am using the NiosII processor on the CycloneIII dev board and would like to send simple commands (e.g. "S200" or "P") to the processor using the JTAG UART interface from Eclipse. I would like to use interrupts to read incoming data and put it into a ring buffer for processing. I have done this before but on a different hardware platform. The issue I'm having is that the interrupt fires immediately and persists. In other words, upon reset, the processor goes into interrupt mode and keeps calling my registered interrupt function.
I believe the code I'm using to set the interrupt for the JTAG UART up is correct, as it actually works, but it shouldn't keep calling it. Also, I checked the status register and the RI flag is set, even though I haven't sent anything from Eclipse's command line. For completeness sake I added the code below.
The question I'm having is: Can I use the JTAG UART simply for interrupt based receiving while being connected to Eclipse, similar to regular UART operation?
static struct JTAG_UART_REGS *JTAG_UART = (struct JTAG_UART_REGS *) (JTAG_UART_BASE | 0x80000000); void UART_init(){ union JTAG_UART_CONTROL_REG JTAG_UART_CONTROL; JTAG_UART_CONTROL.control = 0x0; JTAG_UART_CONTROL.RE = 1; JTAG_UART_CONTROL.WE = 0; JTAG_UART->control = JTAG_UART_CONTROL.control; //alt_ic_irq_enable(0,JTAG_UART_IRQ); alt_irq_register(JTAG_UART_IRQ,JTAG_UART, UART_ISR); } void UART_ISR(){ printf("Interrupt"); }struct and union definitions
struct JTAG_UART_REGS { REGISTER data; REGISTER control; }; union JTAG_UART_DATA_REG { REGISTER data; struct { char DATA; BITS RESERVED :7; BITS RVALID :1; BITS RAVAIL :16; }; }; union JTAG_UART_CONTROL_REG { REGISTER control; struct { BITS RE :1; BITS WE :1; BITS RESERVED1 :6; BITS RI :1; BITS WI :1; BITS AC :1; BITS RESERVED2 :5; BITS WSPACE :16; }; };
I had the same problem on both JTAG-UART and UART, but without interrupt, mine is a polling routine,
it keeps getting random waves of ZEROs from the input even without any input from the hyper terminal.
