Jtag uart
Is there another possibility besides the nios2-terminal to connect to the jtag uart on the PC side ?
Stonie
--- Quote Start ---
originally posted by stonie@May 31 2006, 04:23 PM
is there another possibility besides the nios2-terminal to connect to the jtag uart on the pc side ?
thanks
  stonie
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15723)
--- quote end ---
--- Quote End ---
Hi!
I think this possibility is absent right now :-).
But I have an idea.
Nios2-terminal changes data with HOST 127.0.0.1. On the host side ran JTAGSERVER.
In one&#39;s part JTAGSERVER communicates via Byteblaster with IC(FPGA).
Idea is intercept traffic between JTAGSERVER and nios2-terminal and analyze.
I think analysis would ate so much time for construct your own app.
So......I think this idea should be work.
I found a method to include jtag-uart communication into my host software.
Start nios2-terminal as child process of my host software allows me to communicate via stdin/stdout to the jtag uart.
The same technique is used to invoke the nios2 flash-programmer within my software.
Using a code-sniplet found at http://www.codeproject.com/threads/redir.asp (http://www.codeproject.com/threads/redir.asp) makes this very easy....
have fun,
Stonie
--- Quote Start ---
originally posted by stonie@Jun 1 2006, 03:55 PM
i found a method to include jtag-uart communication into my host software.
start nios2-terminal as child process of my host software allows me to communicate via stdin/stdout to the jtag uart.
the same technique is used to invoke the nios2 flash-programmer within my software.
using a code-sniplet found at http://www.codeproject.com/threads/redir.asp (http://www.codeproject.com/threads/redir.asp) makes this very easy....
have fun,
  stonie
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15763)
--- quote end ---
--- Quote End ---
It is very good news!
Thanks a lot! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
