12748 Discussions
Kernal Panic - Not Syncing : VFS:
This is problem .....I,m using Altera Nios ii board .....i'm getting through serial uart.....
:ph34r: :ph34r: :ph34r: :ph34r: :ph34r:
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.25-uc0 (root@localhost.localdomain) (gcc version 3.4.6)# 15 PR
EEMPT Sat Jul 25 05:15:30 IST 2009
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 8128
Kernel command line:
PID hash table entries: 128 (order: 7, 512 bytes)
console [ttyS0] enabled
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries:
Memory available: 30708k/1760k RAM, 0k/0k ROM (1510k kernel code, 249k data)
Mount-cache hash table entries: 512
net_namespace: 144 bytes
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
NIOS serial driver version 0.0
ttyS0 (irq = 4) is a builtin NIOS UART
smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <nico@cam.org
eth0: SMC91C11xFD (rev 2) at 82110300 IRQ 6 [nowait]
eth0: Ethernet addr: 00:07:ed:0f:b8:f7
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
List of all partitions:
No filesystem could mount root, tried:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
What is the solution .....?
Vivek
