Kernel build fails at this point:
init/.version.o.d: done.
LD init/built-in.o
LD .tmp_vmlinux1
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .text). Region needs to be 1447228 bytes larger.
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .data). Region needs to be 57344 bytes larger.
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .init). Region needs to be 64524 bytes larger.
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .bss). Region needs to be 65076 bytes larger.
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .sbss). Region needs to be 63 bytes larger.
nios2-elf-ld: section .data overlaps section .text
nios2-elf-ld: section .init overlaps section .text
nios2-elf-ld: section .bss overlaps section .text
nios2-elf-ld: section .sbss overlaps section .text
make: *** Error 1
make: *** Error 2
make: Leaving directory `/cygdrive/c/Development/Altera/NiosII/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
I try to make a kernel for a custom board with DDR2-SDRAM.
