12748 Discussions
Kernel panic - not syncing: No init found ??
Hi group,
I have a custom board for which I built a new linux using the latest sources as per instructions on the wiki. Here is what happens when it boots
any thoughts anyone help!! please
uClinux/Nios II
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 8128
Kernel command line:
NR_IRQS:32
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 30204k/2264k RAM, 0k/0k ROM (1393k kernel code, 870k data)
Calibrating delay loop... 28.77 BogoMIPS (lpj=143872)
Mount-cache hash table entries: 512
net_namespace: 264 bytes
NET: Registered protocol family 16
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
ttyJ0 at MMIO 0x4003440 (irq = 2) is a Altera JTAG UART
console [ttyJ0] enabled
brd: module loaded
TCP cubic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 688k freed (0x218a000 - 0x2235000)
Failed to execute /init
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
Please check the initramfs source config. Or try "make" the second time.
- Hippo
tryed make second time (did a make clean first) did not help
not quite sure how to check the initramfs source config.
Some clues:
The final image is about 1.2M.
The init file in the romfs folder is only 9 bytes and shows to be a broken link
any thoughts
a couple of resets to default and its up and running thanks for the support much apreciated I am onto getting the SD card and the ethernet to work!!
