Kernell would not build
The kernell would not build.
------------------------------------------------ Microtronix Linux Extensions Version 1.3, Built December 30th, 2004 ------------------------------------------------ make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'  no emulation specific options.  Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x as source for kernel  CHK     include/linux/version.h  CHK     include/nios2_system.h  HOSTCC  scripts/basic/fixdep scripts/basic/.fixdep.d: done.  HOSTCC  scripts/basic/split-include scripts/basic/.split-include.d: done.  HOSTCC  scripts/basic/docproc scripts/basic/.docproc.d: done.  HOSTCC  scripts/mod/mk_elfconfig scripts/mod/.mk_elfconfig.d: done.  MKELF   scripts/mod/elfconfig.h  HOSTCC  scripts/mod/file2alias.o scripts/mod/.file2alias.o.d: done.  HOSTCC  scripts/mod/modpost.o scripts/mod/.modpost.o.d: done.  HOSTCC  scripts/mod/sumversion.o scripts/mod/.sumversion.o.d: done.  HOSTLD  scripts/mod/modpost  HOSTCC  scripts/kallsyms scripts/.kallsyms.d: done. make: `arch/nios2nommu/kernel/asm-offsets.s' is up to date.  CHK     include/asm-nios2nommu/asm-offsets.h  CHK     include/linux/compile.h  HOSTCC  usr/gen_init_cpio usr/.gen_init_cpio.d: done.  CPIO    usr/initramfs_data.cpio  GZIP    usr/initramfs_data.cpio.gz  AS      usr/initramfs_data.o usr/.initramfs_data.o.d: done.  LD      usr/built-in.o  CC      drivers/char/spi.o /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: error: parse error before '*' token /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: warning: type defaults to `int' in declaration of `spi_ptr' /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: warning: initialization makes pointer from integer without a cast /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: warning: data definition has no type or storage class /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `SPI_Recv_Byte': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: request for member `np_spistatus' in something not a structure or union /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: `np_spistatus_rrdy_mask' undeclared (first use in this function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: (Each undeclared identifier is reported only once /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: for each function it appears in.) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:50: error: request for member `np_spirxdata' in something not a structure or union /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `SPI_Send_Byte': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:62: error: request for member `np_spistatus' in something not a structure or union /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:62: error: `np_spistatus_trdy_mask' undeclared (first use in this function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:63: error: request for member `np_spitxdata' in something not a structure or union /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `spi_write': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:102: error: request for member `np_spistatus' in something not a structure or union /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `spi_read': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:154: error: request for member `np_spistatus' in something not a structure or union /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `spi_lseek': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:221: error: request for member `np_spislaveselect' in something not a structure or union /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `register_NIOS_SPI': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:272: warning: `check_region' is deprecated (declared at /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/include/linux/ioport.h:121) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:272: error: `np_spi' undeclared (first use in this function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `unregister_NIOS_SPI': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:288: error: `np_spi' undeclared (first use in this function) make: *** Error 1 make: *** Error 2 make: *** Error 2 make: *** Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
If i disable the SPI in the kernell configurator the kernell will build without error's
Can someone help ?
nobody used SPI???? tell me if you are using it! and it working
I had the same problem and IMO the SPI component generator has a bug. IIRC I corrected it and was able to compile the kernel after that. If there is no official fix for this I can post it if you want.
Marc
Yes please that would be nice !
Did the SPI bus work?
Do you have got a any example application?
I appriciate it, if you want post it.
Tnx now can i graduate at time i hope. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
I don&#39;t remember exactly what I did. I think the include file was missing some parts and the perl generator was bugged. I don&#39;t know how to add files to a post so I will just paste the code:
With this I just compiled the kernel and started uclinux but I haven&#39;t used it yet. I am supposed to play with this next week. So if you manage to make it work I would be interested to know ;-)
Also if there is an official fix I&#39;m interested too.
Marc
File: altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.kernel_0.1.5\linux-2.6.x\include\asm-nios2nommu\spi.h
#ifndef _ASM_SPI_H_# define _ASM_SPI_H_ 1 /*-------------------------------------------------------------------- * * include/asm-nios2nommu/spi.h * * Derived from various works, Alpha, ix86, M68K, Sparc, ...et al * * Copyright (C) 2004   Microtronix Datacom Ltd * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the * GNU General Public License for more details. * * * Jan/20/2004  dgt     NiosII * ---------------------------------------------------------------------*/ # include <asm/nios.h> int  register_NIOS_SPI( void ); void unregister_NIOS_SPI( void ); # if defined(MODULE) void cleanup_module( void ); int  init_module( void );# endif # if defined(__KERNEL__) int  spi_reset  ( void );# endif # define clockCS 0x01# define temperatureCS 0x02 # define clock_read_base 0x00# define clock_write_base 0x80# define clock_read_control 0x0F# define clock_read_trickle 0x11 # define clock_read_sec 0x00# define clock_read_min 0x01# define clock_read_hour 0x02# define clock_read_day 0x03# define clock_read_date 0x04# define clock_read_month 0x05# define clock_read_year 0x06 # define clock_write_control 0x8F# define clock_write_trickle 0x91# define clock_write_sec 0x80# define clock_write_min 0x81# define clock_write_hour 0x82# define clock_write_day 0x83# define clock_write_date 0x84# define clock_write_month 0x85# define clock_write_year 0x86 # define clock_write_ram_start 0xA0# define clock_write_ram_end 0x100# define clock_read_ram_start 0x20# define clock_read_ram_end 0x80 # define    clock_sec_def 0x11# define clock_min_def 0x59# define clock_hour_def 0x71# define clock_day_def 0x00# define clock_date_def 0x20# define clock_month_def 0x12# define clock_year_def 0x34 # define temp_read_base 0x00# define temp_write_base 0x80# define temp_read_control 0x00# define temp_write_control 0x80# define temp_read_msb 0x02# define temp_read_lsb 0x01 # define MAX_TEMP_VAR 10 // SPI Registers typedef volatile struct  {  int np_spirxdata;       // Read-only, 1-16 bit  int np_spitxdata;       // Write-only, same width as rxdata  int np_spistatus;       // Read-only, 9-bit  int np_spicontrol;      // Read/Write, 9-bit  int np_spireserved;     // reserved  int np_spislaveselect;  // Read/Write, 1-16 bit, master only  int np_spiendofpacket;  // Read/write, same width as txdata, rxdata.  } np_spi; // SPI Status Register Bits enum  {  np_spistatus_eop_bit  = 9,  np_spistatus_e_bit    = 8,  np_spistatus_rrdy_bit = 7,  np_spistatus_trdy_bit = 6,  np_spistatus_tmt_bit  = 5,  np_spistatus_toe_bit  = 4,  np_spistatus_roe_bit  = 3,  np_spistatus_eop_mask  = (1 << 9),  np_spistatus_e_mask    = (1 << 8),  np_spistatus_rrdy_mask = (1 << 7),  np_spistatus_trdy_mask = (1 << 6),  np_spistatus_tmt_mask  = (1 << 5),  np_spistatus_toe_mask  = (1 << 4),  np_spistatus_roe_mask  = (1 << 3),  }; // SPI Control Register Bits enum  {  np_spicontrol_sso_bit   = 10,  np_spicontrol_ieop_bit  = 9,  np_spicontrol_ie_bit    = 8,  np_spicontrol_irrdy_bit = 7,  np_spicontrol_itrdy_bit = 6,  np_spicontrol_itoe_bit  = 4,  np_spicontrol_iroe_bit  = 3,  np_spicontrol_sso_mask   = (1 << 10),  np_spicontrol_ieop_mask  = (1 << 9),  np_spicontrol_ie_mask    = (1 << 8),  np_spicontrol_irrdy_mask = (1 << 7),  np_spicontrol_itrdy_mask = (1 << 6),  np_spicontrol_itoe_mask  = (1 << 4),  np_spicontrol_iroe_mask  = (1 << 3),  }; // SPI Routines. int nr_spi_rxchar(np_spi *spiBase); int nr_spi_txchar(int i, np_spi *spiBase); # endif /*_ASM_SPI_H_*/
File: altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.kernel_0.1.5\linux-2.6.x\arch\nios2nommu\scripts\nios2_system.h\altera_avalon_spi.pm
package altera_avalon_spi; # This module renames the first altera_avalon_spi peripheral to spi require PTF::SystemPTF; require PTF::SystemPTF::Module; use strict; sub run {     my ($system, @spi_names) = @_;     my %module_map = (  "spi" => undef,  );     my @module_map_order = ("spi");     foreach my $module_name (@module_map_order) {  my $module = $system->getModule ($module_name); # determine availability of each module_name  if ($module) {      my $class_name = $module->getClass ();      if ($class_name ne &#39;altera_avalon_spi&#39;) {    print "#error The module name $module_name is of class $class_name.\n";    print "#error This will break the kernel.\n";    print "#error Please rename the module to something else in SOPC Builder.\n\n";      } else {    print "/* No translation for $module_name necessary */\n\n";      }  } else {     # if module name is available, take first uart and translate      while (scalar (@spi_names) > 0) {    my $spi_name = shift (@spi_names);    if (!exists $module_map{$spi_name}) {        my $module = $system->getModule ($spi_name);        my $result;        print "/* Redefining $spi_name -> $module_name */\n";       # start outputing necessary strings        print "#undef  na_" . $spi_name . "\n";        print "#undef  na_" . $spi_name . "_irq\n";        print "\n";       # base address information        $result = $module->getBaseAddress ();        printf ("#define na_%-50s %#010x\n",      ($module_name, hex ($result) | 0x80000000));       # irq information        $result = $module->getIRQ ();        printf ("#define na_%-30s %30s\n",      ($module_name . "_irq", $result));        print "\n";        last;    }      }  }     } } 1;
The kernell is build witout error&#39;s
I will upload it tommorow to my board. And see if it working, but i have no appication to test it.
I have not find any fix for it, maybe someone from Microtronix know it?
Maybe 2 SPI interface will also work ?
