I use the latest kernel with patch r17, and enabled the LED manager.
It make ok, but when booting, it got stucked ... <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 256 (order: 8, 1024 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 30172k/32768k RAM, 0k/0k ROM (1479k kernel code, 799k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) You have init Device 250 ledman: Copyright © SnapGear, 2000-2003.[/b] --- Quote End --- Please help.Link Copied
You can not just enable it.
It does not support Nios dev board. If you want to use ledman, you have to add Nios dev board support.- Mark as New
If you can read Chinese, you can find a LED driver in
Nios II uClinux guide in Chinese by Alex Liu http://www.icwin.net/ (http://www.icwin.net/)- Mark as New
Hi Hippo,
I can read chinese. Thanks.
